Community Member
ISDN PRI Failover with a VoIP gateway
I am trying to configure failover in ISDN trunks with CISCO CME. Actually failover configuration works. But because of the design of the system we have an issue:
CME---0/0/0--->Telco PRI Modem
CME---0/0/1--->VoIP Gateway PRI PORT--->VoIP
Our preference is to use port 0/0/1. And trunk group has been set in that way. If I turn off the VoIP gateway it fails over Telco PRI (0/0/0) successfully.
But if I keep the VoIP gateway turned on and just remove its network port (VoIP) it doesn't fail over to Telco since CME still sees port 0/0/1 up.
The vendor says VoIP gateway is generating cause code 34 if network is down. What should be the config on CME to make it failover to Telco PRI when it gets cause code 34 from one PRI port?
Please see the sample config below:
trunk group XXX
hunt-scheme sequential
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
trunk-group XXX 20
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
trunk-group XXX 15
no cdp enable
dial-peer voice 12 pots
trunkgroup XXX
description Connection to PTT
destination-pattern 9T
direct-inward-dial
If the cause code generates a syslog message then you could use Embedded Event Manager to run commands to shut down serial 0/0/1:15
http://www.cisco.com/en/US/products/ps6815/products_ios_protocol_group_home.html
VIP Super Bronze
Re: ISDN PRI Failover with a VoIP gateway
Batuhan,
You can use IP SLA and Embedded event manager..Configuration details below...
1. First setup some IP SLA monitoring on the VOIP interface(s)
ip sla 201
icmp-echo 10.x.x.1 source-interface Loopback1
2. Then setup some tracking on the SLA object
track 200 ip sla 201 reachability
3. Then use EEM to shut down the interface Serial0/0/1:15  based on your track list:
event manager applet VoIPInterfaceDOWN
event track 200 state down
action 0 cli command "enable"
action 1 cli command "conf t"
action 2 cli command "interface Serial0/0/1:15"
action 3 cli command "shutdown"
action 4 cli command "end"
action 5 syslog priority errors msg "10.x.x.1  unpingable; shutdown serial0/1/0"
event manager applet VoIPInterfaceUP
event track 200 state up
action 3 cli command "no shutdown"
action 5 syslog priority errors msg "10.x.x.1 pingable(recovered); bringing up serial0/1/0"
Or you could also use syslog event to trigger a shut down of the serial port..Ie, when the router generates a syslog message that the VOIP interface is down, it should shut down the E1 interface in question..
event manager applet VoIPInterfaceDown
event syslog pattern "Interface FastEthernet0/1, changed state to down"
action 1.0 cli command "enable"
action 1.1 cli command "config terminal"
action 1.2 cli command "interface Serial0/0/1:15"
action 1.3 cli command "shut"
action 1.4 syslog msg "FastEthernet0/1 is unreachable; Shutting down Primary E1"
event syslog pattern "Interface FastEthernet0/1, changed state to Up"
action 1.3 cli command "no shut"
action 1.4 syslog msg "FastEthernet0/1 is reachable; Bringing up Primary E1"
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
650
