Community Member
ISDN PRI is not working with CISCO 3845 router
I have configured the 3845 router for IDSN termiantion, but I could not get calls or take out goign calls. I am getting error as " temporary failure (41)" when I run show call history voice brief.  Also I am running CME on the same router.
Any hints to resolve this...
Thx
Neethan
1 REPLY
Re: ISDN PRI is not working with CISCO 3845 router
Hi Neethan,
Please confirm the below points:
1. Check the incoming and outgoing is enabled at ISP side
2. Check the ISDN status on router
Use the following command to check the ISDN Status:
Router# show isdn status
3. Check the DSP resources on router
Use the following command to check the DSP resources:
Router# show diag
Router# show inventory
4. Check the current IOS for any bugs.
Use the following command to debug the ISDN calls:
Router# debug isdn q931
Please send the output of both the commands to find out the root cause of the issue (If possible the Router configuration as well).
Vaijanath
Vaijanath S.
444
