ISDN PRI Problem!
Hi all,
I have a Cisco 2821 router with VWIC2-2MFT-E1/T1 to connect to PSTN via E1 PRI. I think that all the configurations are OK (as I had done a case before and the configurations are the same) but Layer 2 cannot go to MULTIFRAME_ESTABLISHED.
Could anyone give me some explains or instructions.
Thanks and regards,
hoanghiep
The configurations:
card type e1 0 0
no aaa new-model
resource policy
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
no dspfarm
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-24 ##I have also 8 FXO ports so there're enough DSP for only 24 timeslots### (same thing for the already-running-system I mentioned above)
interface Serial0/0/0:15
no ip address
encapsulation ppp
isdn incoming-voice voice
keepalive 10 3
no cdp enable
show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80FF7FFF
Number of L2 Discards = 0, L2 Session ID = 190
debug isdn q921
*Aug 18 04:57:26.575: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*Aug 18 04:57:26.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:27.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:28.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:29.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Silver
Re: ISDN PRI Problem!
i think u have to check from Telco side to make sure ur PRI is ready and activated from their side.
i had like this before and it was a Telco issue.
hth
/majdi
Hello
Have you tried changing the CRC4 in the framing - in the UK we use CRC4.
Silver
is this MGCP gateway?, if so do you have the full config?
Ajaz
Bronze
Put 'encapsulation hdlc' instead of the encapsulation ppp you have, reload and you should be fine.
HTH, Avner.
I think the linecode command is missing in controller E1
242
