ISDN PRI to BRI
Somebody configured ISDN from PRI to BRI? Is there any difficult?
Peterson
Hi Peterson,
This is the same configuration as you would do PRI-H323, BRI-H323, but just no H323. Some pots dial peers, the ISDN commands, and voice port configuration as normal.
hth,
nick
Thanks nick!
paolo bevilacqua
Ola' Peterson,
check this document:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00804794c6.shtml
