Community Member
ISDN PRI Troubleshooting
Has anyone ever run into a situation where a PRI is sending a "#" at the end of a number that is being passed to the telco. I have a situation where two of my dial-peers are forwarding a "#" after the end of the string that I appear to be forwarding. Hopefully someone has run into this before and can help me out. If it helps at all, the two peers are for 8911, and 10 digit dialing.
Steve
Re: ISDN PRI Troubleshooting
Hi Steve,
It's coming from somewhere else, I can tell you that - I've never seen a gateway randomly add something like this unless you're running a script/application on the dial peer.
Check what the users are dialing and work with your dial plan.
hth,
nick
Community Member
Thanks Nick. The only difference between these calls and the ones that go through successfully are that the numbering plan shows up as "unknown" when I watch the call via debug isdn q931. Would this make a difference?
Steve
Hi Steve,
It could absolutely make a difference. Providers can be very picking about the numbering plan/type, and will reject calls based up on it.
-nick
Community Member
Can I then use a translation-profile to change the numbering plan of the number that I am forwarding to the telco?
Steve
Hi Steve,
Yes, on either one of those you can do translation on incoming or outgoing.
-nick
Hall of Fame Super Gold
There is even an easier way "isdn map address ... " under serial interface.
VIP Super Bronze
why dont you do a test call yourself. Then run debug isdn q931..Also take ccm traces and post here. Lets have a look.
In clude the calling number and the called number plus the time of the call.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
406
