Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ISDN Q931 Message
Guys, we all know about debug isdn q931 output message, I've 4 doubts in that. (which are in highlighted form in the attached snapshot)
  • What is meaning & use of Channel ID [which is i = 0xA9839F in our case] (Line 30) ?
  • What is pd & what does that mean  (Line 31) ?
  • What does this mean i = 0x0081 (Line 10) (I thing I know about this that this value is in hexadecimal, after that 0081 represent what ?)
        & i = 0x80 (Line 12)
Please check the attached snapshot for your reference.
Thank you in advance.
Thanks: Mohit Grover MCP, MCSE, MCITP CCIE Voice # 35961 BCA (Network Communications) MCA (Network Communications)
ISDN Q931 Message
Hi Mohit,
Below is the required information:-
1). channel id is composed of Bearer capability and the channel (i.e. slot occupied for the call)
     for e.g in your case Bearer Capability is = 0x8090A3 and channel is 31 which int turns into 0xA9839F
Here, A398 value is interchanged from the bearer capability and 9F (80+1F) is the hex value of channel no 31 (hex=1F)
2). pd stands for protocol discriminator which means that value is used to distinguish messages for user-network call control from other messages.
for e.g
pd=8 for Q.931 user-network call control messages
pd=9 for Q.2931 user-network call control messages
3). Progress Ind i = 80 means it indicates that tones and announcements are available for that particular call.
     various other progress indicaiton is as below:-
  • PI=0 No progress indicator is included. Message type: Setup
  • PI=1 Call is not end-to-end ISDN; further call progress information may be available in-band. Message type: Alert, setup, progress, connect
  • PI=2 Destination address is non-ISDN Message type: Alert, progress, connect
  • PI=3 Origination address is non-ISDN Message type: Setup
  • PI=8 In-band information or appropriate pattern is now available Message type: Alert, progress, connect
4). calling party & called party information is as below:
· 80 the router
· 81 the private network near the local user (possibly a local private branch exchange [PBX])
· 82 the public network near the local user (local telco switch)
· 83 the transit network (in the ISDN cloud)
· 84 the public network near the remote user (remote telco switch)
· 85 the private the network near the remote user (possibly a remote PBX)
· 87 the international network
· 8A a network beyond the internetworking point
Regards, Nishant Savalia
Re: ISDN Q931 Message
Hi Nishant, thanks for your quick response.
Channel ID is composed of Bearer capability + Channel
Bearer Cap -> 0x8090A3 represents Voice/Speech call (G711 - A-law)
For e.g. In our case Bearer Capability is = 0x8090A3 (which represent that G711 A Law codec is being used) and channel is 31 which int turns into 0xA9839F (how it got turn into this value 0xA9839F, is that a hexa. addition or sort of something)
A398 value is interchanged from the bearer capability and 9F (80+1F) is the hex value of channel no 31 (hex=1F) ?
Hall of Fame Super Gold
ISDN Q931 Message
ISDN Q931 Message
That is really helpful Paolo, Thanks
Thank you for the nice rating and good luck!
1206
