ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Hi All,
(lab purposes)
I'm having issues with my E1 voice PRI interface
I configured one of my sites ( CME ) with E1 pri but my router keeps telling the above messages.
If i look in my PSTN voice router i get the same
SiteC:
Feb  7 20:45:10.573: %CONTROLLER-5-UPDOWN: Controller E1 0/2/0, changed state to down (10 SES)
Feb  7 20:45:10.573: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 11
Feb  7 20:45:10.573: ISDN Se0/2/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Feb  7 20:45:10.577: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/2/0:15, TEI 0 changed to down
Feb  7 20:45:10.577: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Feb  7 20:45:12.573: %LINK-3-UPDOWN: Interface Serial0/2/0:15, changed state to down
Feb  7 20:45:20.573: %CONTROLLER-5-UPDOWN: Controller E1 0/2/0, changed state to up
Feb  7 20:45:20.573: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 11 to priority 1
Feb  7 20:45:20.581: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/2/0:15, TEI 0 changed to up
Feb  7 20:45:22.573: %LINK-3-UPDOWN: Interface Serial0/2/0:15, changed state to up
Feb  7 20:46:39.608: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Restart Indicator i = 0x80
Feb  7 20:46:39.608: ISDN Se0/2/0:15 Q931: TX -> RESTART_ACK pd = 8  callref = 0x8000
Feb  7 20:46:39.616: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
        Channel ID i = 0xA98383
                Exclusive, Channel 3
Feb  7 20:46:39.616: ISDN Se0/2/0:15 Q931: TX -> RESTART_ACK pd = 8  callref = 0x8000
Feb  7 20:46:40.608: ISDN Se0/2/0:15 Q931: TX -> RESTART_ACK pd = 8  callref = 0x8000
Feb  7 21:04:27.054: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0086
        Cause i = 0x80E6 - Recovery on timer expiry
Feb  7 21:04:27.054: ISDN Se0/2/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SET    Total All
PSTN-WAN router:
PSTN-WAN#
Feb  7 22:40:19.083: ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Site C is configured with the following:
controller E1 0/2/0
pri-group timeslots 1-4,16
framing CRC4/linecode hdb3
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
PSTN-WAN config
interface Serial0/0/0:15
description ** E1 PRI D-CHANNEL TO BR2-RTR **
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
no cdp enable
controller E1 0/0/0
clock source internal
description ** E1 VOICE CONNECTION TO SITEC-RTR **
Can you paste your whole config?
Yosh
HTH Regards, Yosh
Hi Yahshiel,
I've attached the 2 configs .in the first discussion.
New update:
ive configured everthing from scratch, removed all the e1 pri interfaces
( voice-port shut.... no isdn switch......after that a no shut and defined pri groups timeslots etc etc)
matser and slave site
I see the line at PSTN site still bouncing:
PSTN-WAN#
PSTN-WAN#
Feb  7 23:58:51.479: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
PSTN-WAN#
Feb  7 23:59:05.483: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
PSTN-WAN#
Feb  8 00:00:08.719: %ISDN-6-CHAN_UNAVAILABLE: Interface Se0/0/0:15 Requested Channel 4 is not available
PSTN-WAN#
Feb  8 00:00:48.723: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
PSTN-WAN#
Feb  8 00:00:54.727: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
PSTN-WAN#
Feb  8 00:01:13.571: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
PSTN-WAN#
Feb  8 00:01:18.575: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
PSTN-WAN#
SiteC:
SiteC-RTR#
Feb  7 22:17:42.013: %CONTROLLER-5-UPDOWN: Controller E1 0/2/0, changed state to down (10 SES)
Feb  7 22:17:42.013: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 11
Feb  7 22:17:42.013: ISDN Se0/2/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Feb  7 22:17:42.017: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/2/0:15, TEI 0 changed to down
Feb  7 22:17:42.017: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Feb  7 22:17:44.013: %LINK-3-UPDOWN: Interface Serial0/2/0:15, changed state to down
Feb  7 22:17:59.013: %CONTROLLER-5-UPDOWN: Controller E1 0/2/0, changed state to up
Feb  7 22:17:59.013: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 11 to priority 1
Feb  7 22:17:59.017: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/2/0:15, TEI 0 changed to up
Feb  7 22:18:01.013: %LINK-3-UPDOWN: Interface Serial0/2/0:15, changed state to up
Feb  7 22:18:10.078: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
Feb  7 22:18:10.082: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
        Channel ID i = 0xA98381
                Exclusive, Channel 1
Feb  7 22:18:10.090: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
        Channel ID i = 0xA98384
                Exclusive, Channel 4
Feb  7 22:18:10.094: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
Feb  7 22:18:10.102: ISDN Se0/2/0:15 Q931: RX <- RESTART pd = 8  callref = 0x0000
Hi Mohamed
Can you please activate a debug isdn q921 and post the output.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
  points
Would need the dbebug along with the  show command requested below:
show controller e1 0/2/0
debug isdn q921
Kevin
Looking at your WAN PSTN config, it looks like the CCIE VOICE PSTN config.
This issue occurs when you are  testing call-routing (Inbound/Outbound) then the L3 flaps and router stops responding.
The debugs you pasted about indicates that you Layer 2 is flapping and the Telco being at your end which is controllered by you. You need to check if the hardware resources are fine.
show voice dsp group all
Let me know the same.
Kevin
Kevin==>
SiteC:
E1 0/2/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (587 seconds elapsed):
     313 Line Code Violations, 686 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 170 Line Err Secs, 0 Degraded Mins
     119 Errored Secs, 16 Bursty Err Secs, 83 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
     1533 Line Code Violations, 3007 Path Code Violations
     12 Slip Secs, 0 Fr Loss Secs, 413 Line Err Secs, 1 Degraded Mins
     273 Errored Secs, 57 Bursty Err Secs, 190 Severely Err Secs, 65 Unavail Secs
  Data in Interval 2:
     1330 Line Code Violations, 2475 Path Code Violations
     14 Slip Secs, 2 Fr Loss Secs, 296 Line Err Secs, 0 Degraded Mins
     222 Errored Secs, 60 Bursty Err Secs, 166 Severely Err Secs, 154 Unavail Secs
  Data in Interval 3:
     1170 Line Code Violations, 2654 Path Code Violations
     30 Slip Secs, 0 Fr Loss Secs, 406 Line Err Secs, 0 Degraded Mins
     277 Errored Secs, 78 Bursty Err Secs, 190 Severely Err Secs, 91 Unavail Secs
  Data in Interval 4:
     1958 Line Code Violations, 3007 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 360 Line Err Secs, 3 Degraded Mins
     291 Errored Secs, 87 Bursty Err Secs, 177 Severely Err Secs, 0 Unavail Secs
  Data in Interval 5:
     8191 Line Code Violations, 4118 Path Code Violations
     3 Slip Secs, 0 Fr Loss Secs, 61 Line Err Secs, 0 Degraded Mins
     34 Errored Secs, 10 Bursty Err Secs, 33 Severely Err Secs, 771 Unavail Secs
  Total Data (last 5 15 minute intervals):
     14182 Line Code Violations, 15261 Path Code Violations,
     59 Slip Secs, 2 Fr Loss Secs, 1536 Line Err Secs, 4 Degraded Mins,
     1097 Errored Secs, 292 Bursty Err Secs, 756 Severely Err Secs, 1081 Unavail Secs
PSTN:
E1 0/0/0 is up.
  Description: ** E1 VOICE CONNECTION TO BR2-RTR **
  Far End Block Errors Detected
  No alarms detected.
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (668 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
     4 Line Code Violations, 4 Path Code Violations
     1 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins
     3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 1 15 minute intervals):
     4 Line Code Violations, 4 Path Code Violations,
     1 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins,
PSTN:
debug isdq921
PSTN-WAN#term mon
Feb  8 00:39:20.035: ISDN Se0/0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=0
Feb  8 00:39:20.035: ISDN Se0/0/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=0
Feb  8 00:39:20.035: ISDN Se0/0/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=0
Feb  8 00:39:20.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Feb  8 00:39:21.035: ISDN Se0/0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=0
PSTN-WAN#
Feb  8 00:39:27.751: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Feb  8 00:39:27.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Feb  8 00:39:28.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
PSTN-WAN#
PSTN-WAN#
Feb  8 00:39:29.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Feb  8 00:39:30.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
PSTN-WAN#
Feb  8 00:39:32.035: ISDN Se0/0/0:15 Q921: Net TX -> RRp sapi=0 tei=0 nr=0
Feb  8 00:39:32.039: ISDN Se0/0/0:15 Q921: Net RX <- RRf sapi=0 tei=0 nr=0
PSTN-WAN#
Feb  8 00:39:36.751: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Feb  8 00:39:36.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Feb  8 00:39:37.751: ISDN Se0/1/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
SiteC:
debug isdn q921
SiteC-RTR#
Feb  7 22:57:36.341: ISDN Se0/2/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
Feb  7 22:57:36.345: ISDN Se0/2/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=0
Feb  7 22:57:41.665: ISDN Se0/2/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=0 nr=0
Feb  7 22:57:41.685: ISDN Se0/2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=0 nr=1
Feb  7 22:57:41.685: ISDN Se0/2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=1
Hi Carlo how r u?
Kevin====>>>  dsp's seems fine
strange this worked fine before.
Have to mention , i i'm placing test calls from my site c phone to pstn phones something the calls goes out.
Sometimes i have a dead end, or busy tone.
After that when i debug i get all the output what i have i have stated before
PSTN-WAN#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 23.8.6
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used: 0
dsp 2:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
    Signaling channels allocated: 0
    Credits used: 0
dsp 3:
  Max credits: 240
    Credits used: 0
dsp 4:
  Max credits: 240
    Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
  0 DSP resource allocation failure
SiteC-RTR#sh voice dsp group all
dsp 1:
  Max credits: 240
  num_of_sig_chnls_allocated: 4
    Signaling channels allocated: 4
    Credits used: 0
Try adding this under the serial interface E1:
interface serial 0/2/0:15
isdn negotiate-bchan
isdn bchan-number-order ascending
Rate this post accordingly.
Kevin
unfortunately didnt work.
Having the same issue
Sounds a little bit stupid but it worked.
The problem was i think a cable issue.
I tried another crossover cable from one of my other "Sites"
And seems this works fine, from both sites i can call.
DID also works fine.
Anyway i need to check my cables, could be a problem.
I'll keep this discussion open maybe the problem will arise in case the problem happens again.
Hi Mohamed.
Your PSTN E1 controller, reports a Far End Block Errors Detected this usually indicates a Layer 1 issue.
I would start checking the cable connecting the PSTN E1 controller with Site C E1 Controller.
Let me know
Carlo
ooops
You were faster
Glad you found the issue
Carlo
Re:ISDN Se0/1/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L
Hi carlo
Yes thats right i was busy for hours...
But glad it worked..
Thanks for the thinking and support
We keep in touch ;-)
Sent from Cisco Technical Support Android App
2187
