06-15-2010 03:27 AM - edited 03-15-2019 11:14 PM
Hi all,
anyone seen something like this before:
This is the router we are using as voice gatway:
Cisco Router 2801
IOS: c2801-advipservicesk9-mz.124-24.T2
2 FastEthernet interfaces
2 ISDN Basic Rate interfaces <----------- Two ISDN lines
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
1 DSP, 8 Voice resources
1 cisco Internal Service Module(s)
Cisco Unity Express 7.1.4 in slot 0
And this is our very basic setup:
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn static-tei 0
And now the mystery:
If we make an incoming call we will see it on both BRI interfaces simultaneously:
Jun 15 12:28:10: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x3D <-------- BRI0/0/0
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x1081, 'xxxxxxxxx3'
Plan:Unknown, Type:International
Called Party Number i = 0x81, '5124'
Plan:ISDN, Type:Unknown
High Layer Compat i = 0x9181
Jun 15 12:28:10: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x3D <-------- BRI0/0/1
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Jun 15 12:28:10: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xBD
Channel ID i = 0x89
Exclusive, B1
Jun 15 12:28:10: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xBD
Channel ID i = 0x89
Exclusive, B1
Jun 15 12:28:10: ISDN BR0/0/0 Q931: TX -> ALERTING pd = 8 callref = 0xBD
Jun 15 12:28:10: ISDN BR0/0/1 Q931: TX -> ALERTING pd = 8 callref = 0xBD
Jun 15 12:28:14: ISDN BR0/0/0 Q931: TX -> CONNECT pd = 8 callref = 0xBD
Channel ID i = 0x89
Exclusive, B1
Jun 15 12:28:15: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x3D
Cause i = 0x87A9 - Temporary failure
Jun 15 12:28:15: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8 callref = 0x3D
Jun 15 12:28:15: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xBD
Jun 15 12:28:16: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xBD
Jun 15 12:28:16: ISDN BR0/0/0 **ERROR**: L2_AdvanceVA: TX_ack_queue empty <------- Error: The call is disconnected
Jun 15 12:28:16: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
Jun 15 12:28:16: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
Jun 15 12:28:16: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jun 15 12:28:16: ISDN BR0/0/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jun 15 12:28:18: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
Jun 15 12:28:20: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
Jun 15 12:28:20: ISDN BR0/0/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jun 15 12:28:32: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Jun 15 12:28:32: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
Strange, isn't it?
Has anyone seen somthin similar?
Is it possible that the Telco switch has a configuration problem?
Many thanks,
Michael
Solved! Go to Solution.
06-15-2010 03:54 AM
ISDN2 NTEs typically have two ports.
It looks to me like someone has helpfully connected both ports on the router to both ports on the NTE.
You get 2 channels per port, and 2 channels per ISDN2 circuit, so there's no benefit to doing this. Shut down one port and it will probably work better; then check over the cabling.
If you have two BRI circuits, connect one to each port on the router.
If you have one two-channel BRI, then connect it to a single port.
Aaron
Please rate helpful posts...
06-15-2010 03:54 AM
Aaron
06-15-2010 04:16 AM
Hi Aaron,
thank you for your reply.
We should have two ISDN circuites - at least that is what we ordered (so we can have 4 phone calls simultaniously).
I will have someone to check the cabeling. It's not impossible that someone did a big mistake.
I will keep you up to date.
PS: If I do a shutdown on one interface we can have incoming and outgoing phone calls (although we can have only 2 calls simultaniously)
Thank you for your hint,
Michael
06-15-2010 04:20 AM
No problem, let us know how you get on.
Aaron
06-18-2010 03:41 AM
Hi Aaron,
you are right! It was a cabling issue.... on site is a NTE with 5 Ports labeled 1 1 3 4 5
Port 1 and 1 use the same bus - who would have thought this? :-)
Thankys for your help.
06-18-2010 03:43 AM
Hi Michael
Glad to hear it's fixed :-)
Aaron
