Community Member
ISDN to SIP (outbound) calls are failing after too many 183 sessions
I am trying to make outbound SIP calls from my cisco gateway, some how i am recieving too many 183 session progress and than call fails from 408 Request timeout.
Please if some one help me to solve this issue.
here is my call trace, i am not showing all 183 session progress here
it has 3,4 more same messages
*Feb 21 22:42:17.875: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK4F07DC16
From: <sip:4444444444@192.168.0.1>;tag=685B115C-562
To: <sip:55555555555@10.1.2.3>;tag=4EB5B022-3E9BA47-0A11F61A
Call-ID: 9A7CF310-78111D5-B39FFC41-39B5E64@192.168.0.1
CSeq: 101 INVITE
Timestamp: 982795330
Contact: <sip:10.1.2.3:5060;transport=udp>
Require: 100rel
RSeq: 1
Allow: CANCEL,INFO,OPTIONS,BYE,PRACK,UPDATE
Content-Length: 0
*Feb 21 22:42:25.971: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 0
*Feb 21 22:42:39.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.168.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.2.3:5060;branch=z9hG4bK08tahp30doe1qjcrb301.1
To: <sip:192.168.0.1>
Call-ID: 4EB5B03F-00127829@asnmdjfj001
CSeq: 1227 OPTIONS
Supported: timer
Max-Forwards: 69
Content-Length: 0
*Feb 21 22:42:39.779: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.0.1>;tag=685B8524-1C57
Date: Wed, 21 Feb 2001 22:42:39 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1227 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY
, INFO, UPDATE, REGISTER
Accept: application/sdp
Allow-Events: telephone-event
Content-Length: 164
Content-Type: application/sdp
v=0
o=CiscoSystemsSIP-GW-UserAgent 6831 9300 IN IP4 192.168.0.1
s=SIP Call
c=IN IP4 192.168.0.1
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 3
*Feb 21 22:42:42.191: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4444444444@192.168.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.2.3:5060;branch=z9hG4bK5hbef0104gg1cks1k081.1
From: <sip:55555555555@10.1.2.3>;tag=4EB5B022-3E9BA47-0A11F61A
To: <sip:4444444444@192.168.0.1>;tag=685B115C-562
CSeq: 1 BYE
Supported: timer
Max-Forwards: 69
Reason: SIP ;cause=408
Reason: Q.850 ;cause=127 ;text="Interworking, unspecified"
Content-Length: 0
Received:
SIP/2.0 408 Request Timeout
CSeq: 101 INVITE
Content-Length: 0
*Feb 21 22:42:42.199: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:55555555555@10.1.2.3:5060 SIP/2.0
Date: Wed, 21 Feb 2001 22:42:42 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
dial-peer voice 100 voip
description *****OUTBOUND********
destination-pattern 00T
translate-outgoing called 55
voice-class codec 12
session protocol sipv2
session target ipv4:10.1.2.3
1 ACCEPTED SOLUTION
You are recieving 183 message with the header "Require: 100rel"
It is expecting the Provisional response PRACK Response back.
Add this in your gateway
voice service voip
sip
  rel1xx supported
Senthilkumar
Green
You calls are fail.ing due this :-
Content-Length: 0
In order that we check your internetworking can you pleae post
show run
Alex
Regards, Alex. Please rate useful posts.
Community Member
Re: ISDN to SIP (outbound) calls are failing after too many 183
Hi Alex,
I am attaching the sh run, file as requested.
One question, In 183 session messages (require : 100rel) , which some how my gateway not sending 200ok.
why is that?
Or may be you will find answer in sh run.
Thanks in advance.
Green
can you first try adding the following to your config:-
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface fast0/0
  bind media source-interface fast0/0
can you arrange a retest
regards
Alex
Community Member
hi,
i done the retest, unfortunately result is same Failed with 408 time out, cause 127 after too many 183 sessions
voice service voip
fax protocol none
h323
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
This gateway was working fine on these settings, but now when i am trying to send calls to my new carrier its failing.
voice service voip
sip
  rel1xx supported
Senthilkumar
Community Member
Hi Senthilkumar,
Thank you very much, you have solved my problem.
you are great.
I would like to Thanks Alex aswell, atleast he tried to help me.
Best Regards
Tausiif
1601
