ISDN
Hello
I already interliguei cisco voice gateway with Philips and Avaya PABX by ISDN QSIG. In both, the name called was not transmitted. I saw some papers and discussions here in netpro with professionals with the same diagnosis. But if I connect two PABX Siemens by ISDN QSIG this information now. If I connect two PABX Philips also. Siemens has a protocol called T-QSIG which is the QSIG changed. Philips I know but should use something like that. My question is: If I interconnect 2 cisco voice gateway by ISDN QSIG (even knowing that other interconnections would be best, but as a curiosity), the name would be called shared?
Hall of Fame Super Gold
Re: ISDN
If you these are GWs for CM with MGCP, name support depends by the qsig settings in gw configuration page.
Else configure "voice service voip - qsig decode" and name will be supported.
Re: ISDN
"voice service voip - qsig decode", only between Cisco GW or between GW and PABX another vendor too?
Re: ISDN
Works with anyone.
Boa interligacao!
Re: ISDN
I'll go configure this week!
Obrigado!
129
