ISDN
I have a cisco 2800 series router with 1 E1 adapter(2 ports but one used).Could i use this card to set up an isdn connection using 30 channels.If not which card can i use?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ISDN
As mentioned above, VWIC or VWIC2.
Re: ISDN
Which specific card do you have? I'm assuming you want to setup voice connectivity?
Brandon
Re: ISDN
The card reference is NM-2CE1T1-PRI.Please advise me if it is supported.
Thank you
Re: ISDN
we already have tables on that, have you reviewed them????
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68.pdf
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: ISDN
I could not open this link.
In fact i would like to set up vocal banking using an isdn connection (30 channels).I would like to know if the NM-CE1T1-PRI could do this.
Re: ISDN
Hi, you need VWIC or VWIC2 card with a PVDM2-32 for a full E1 voice PRI.
You cannot use the NM-CE1T1-PRI for voice.
Re: ISDN
Re: ISDN
Hello what I'm trying to tell you is that the NM-1CE1T1-PRI does not support voice and you need a VWIC or VWIC2 card, plus a PVDM2-32.
As a recognition to those providing answers, please rate useful posts with the scrollbox below!
Re: ISDN
I saw a table describing the card as 1-port Channelized E1/T1/ISDN PRI network module.This means that the card can support ISDN.Isn't it?
Re: ISDN
As mentioned above, it supports ISDN PRI for DATA, but not ISDN PRI for VOICE.
For voice compatibility, you have to look at different tables like:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
Re: ISDN
Ok i suggest you take a look a this table too.
What is the reference of the VWIC card you mentionned?
Re: ISDN
The document is about DATA pri. For VOICE you need VWIC, note the V that means VOICE support.
Re: ISDN
Thanks a lot.So what specific card do you recommend for isdn voice and data at the same time?
Re: ISDN
336
