12-19-2011 02:48 AM - edited 03-16-2019 08:36 AM
We are install a PRI in Gibraltar Country with the provider Gib Telecom. The issue is in the Layer 2 ISDN. The provider had done twice the test ISD30, they connect some equipment (they disconnect the cable connected to the router card E1 and connect they equipment) in our side and call to mobile successfull. //////////////////////////////////////////////// THE STATE JUMP FROM TEI_ASSIGNED TO AWAITING_ESTABLISHMENT ISDN Serial0/0/0:15 interface dsl 0, interface ISDN Switchtype = primary-net5 L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003 Layer 1 Status: ACTIVE Layer 2 Status: TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0xFFFF7FFF Number of L2 Discards = 0, L2 Session ID = 206 Total Allocated ISDN CCBs = 0 ISDN Serial0/0/0:15 interface dsl 0, interface ISDN Switchtype = primary-net5 L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003 Layer 1 Status: ACTIVE Layer 2 Status: TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0xFFFF7FFF Number of L2 Discards = 0, L2 Session ID = 206 Total Allocated ISDN CCBs = 0 /////////////////////////////////////////////// WE NOT SEE INCOMING DATA IN THE COUNTER "packets input" Interface Serial0/0/0:15 is up, line protocol is up (spoofing) Hardware is DSX1 MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, crc 16, loopback not set Keepalive set (10 sec) Last input never, output 00:00:04, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 5764 packets output, 17292 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions ///////////////////////////////////////////// WE NOT SEE RX FOR A LONG TIME. GW-1-AIR-GIBR-PR#debug isdn q921 *Dec 14 10:03:55.786: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME *Dec 14 10:03:55.786: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0 *Dec 14 10:03:56.786: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0 *Dec 14 10:03:57.786: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0 *Dec 14 10:03:58.786: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0 ////////////////////////////////////////////// WE NOT SEE ANY ERROR IN THE CONTROLLER E1 GW-1-AIR-GIBR-PR#show controller e1 E1 0/0/0 is up. Applique type is Channelized E1 - balanced No alarms detected. alarm-trigger is not set Version info FPGA Rev: 08121917, FPGA Type: PRK4 Framing is CRC4, Line Code is HDB3, Clock Source is Line. International Bit: 1, National Bits: 11111 Data in current interval (567 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs ////////////////////////////////////////////// Our CUCM is configures with MGCP with this parameters: Global ISDN Switch Type = EURO Switchback Timing = Gracefull ----- Product = Cisco MGCP E1 Port Gateway = GW-1-AIR-GIBR-PR Device Protocol = PRI de acceso digital Registration = Registered with Cisco Unified Communications Manager 10.0.16.11 IP Address = 10.0.16.14 Device is trusted Device is not trusted End-Point Name = S0/SU0/DS1-0@GW-1-AIR-GIBR-PR NetworkLocale = United Kingdom ----- PRI Protocol Type = PRI EURO Protocol Side = User Channel Selection Order = Bottom UP Channel IE Type = User Number When 1B PCM Type = A-law ----- Line Coding = HDB3 Framing = CRC4 Clock = EXTERNAL EURO HDB3 ----- Cisco Unified CM Administration System version: 8.5.1.12900-7
Solved! Go to Solution.
12-21-2011 02:21 AM
Bad frame means you are network and are receiving a network frame.
You should be user always and work with H.323, as MGCP is unreliable.
12-19-2011 04:47 AM
I see you are set to use CRC4 for framing.
Not sure what the correct setting for Gibroltar is.
Try making it NO CRC4 on both the router & CUCM.
Alex
12-19-2011 07:13 AM
CRC setting is fine, otherwise controller would not be error free.
And, CRC settings are on router only, not on CUCM.
12-19-2011 07:12 AM
When they did the testing using their equipment, you were present and have seen that personally ?
12-19-2011 08:01 AM
Unfortunately I was not there, Im the enginneer and Im work remotely, but our techinicial level 1 (remote hand) was there.
in the CUCM there a re option for line codig and CRC when you configure MGCP.
12-19-2011 08:25 AM
Oscar,
What is the config of your interface S0/0/0:15
Alex
12-19-2011 08:32 AM
In my gateway I have:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
echo-cancel coverage 64
cptone GB
ccm-manager redundant-host 10.0.16.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.0.16.11 10.0.16.10
ccm-manager config
mgcp
mgcp call-agent 10.0.16.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp profile default
12-19-2011 08:50 AM
This all looks good.
There seem be a few issues and old bugs re this.
Can you try :-
no mgcp
int s0/0/0:15
shut
! wait 10 seconds
no shut
mgcp
See if this helps
Alex
12-19-2011 08:48 AM
Ask telco to come back onsite and repeat tests.
No packets received by router = circuit not active.
12-19-2011 10:04 AM
We did the no mgcp and not help.
Im asking the Telco repeat the test.
Cisco Enginner also delete config of the MGCP and config with H323 but still not up the L2 ISDN (Q921). Cisco ENginner found that we not receive RX just TX.
debug isdn q921 and got:
ec 19 17:25:55.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:25:56.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:02.450: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 19 17:26:02.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:03.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:04.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:05.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:11.450: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 19 17:26:11.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 19 17:26:12.450: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
NEW Config with H323 (With out MGCP):
controller E1 0/0/0
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
12-21-2011 02:14 AM
I change from “user” to “network” in MGCP and now for first time I have receive data from the switch isdn. what is mean BAD FRAME?. How can I solved?.
Dec 21 10:06:47.700: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:06:47.700: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:48.700: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:49.700: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:50.700: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:57.412: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:06:57.716: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:06:57.716: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:58.408: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:06:58.716: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:06:59.412: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:06:59.716: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:00.416: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:07:00.716: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:07.731: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:07:07.731: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:08.731: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:09.731: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:10.731: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:17.743: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:07:17.743: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:18.743: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:19.743: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:20.743: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:07:27.495: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
Dec 21 10:07:27.671: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
Dec 21 10:07:29.495: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to down
Dec 21 10:07:37.923: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
Dec 21 10:07:37.923: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec 21 10:08:29.495: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
Dec 21 10:08:29.523: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:08:29.523: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:30.523: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:31.495: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to up
Dec 21 10:08:31.523: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:32.523: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:39.535: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:08:39.535: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:39.923: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec 21 10:08:40.535: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:41.535: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:42.535: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:49.547: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:08:49.547: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:50.546: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:51.546: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:52.546: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:08:59.562: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
Dec 21 10:08:59.562: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:09:00.562: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:09:01.562: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:09:02.562: ISDN Se0/0/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
Dec 21 10:09:04.738: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:09:05.730: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:09:06.734: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:09:07.738: ISDN Se0/0/0:15 Q921: Net RX <- BAD FRAME(0x02017F)
Dec 21 10:09:09.574: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
12-21-2011 02:21 AM
01-04-2012 12:57 AM
We are working with new generation routers and PRI cards, for the router "2900 series" and card PRI "VWIC3". This newest equipment have not reported till now any BUG about compatibility with Switchs ISDN providers.
Today We upgrade the IOS from c2900-universalk9-mz.SPA.151-3.T1.bin to c2900-universalk9-mz.SPA.152-2.T.bin and this solve this issue.
So in conclution from the beginner the configuration in boths sides (provider Gib Telecom and Our Cisco router- CUCM) was ok. The issue was the firmware router!!!.
cisco is reporting this new BUG.
