ISM-SRE-300-K9 - Software installation
I have the following router
Cisco CISCO2901
flash0:c2900-universalk9-mz.SPA.151-4.M2.bin
containing the following CUE inbuilt
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
PID: ISM-SRE-300-K9
I want to install the software for this Cue card. 2 quickquestion
which will be the software to be installed on router? I have cue-installer.ise.8.5.1 and cue-installer.sme.8.5.1
How to install software on the router (other than ftp)
1 ACCEPTED SOLUTION
Blue
cue-installer.ise.8.5.1 is for Integrated Service Engine and cue-installer.sme.8.5.1 for Services Ready Engine. As your hardware is SME you should use the cue-installer.sme.8.5.1.
Following is the procedure
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_5/install/installsre.html
regards
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Gold
Download software from csico.com, and follow the installation documentation.
Blue
regards
Ronak patel
Ya i did it already. I nailed it.
Can you tell me the diff between ISE and SME ? Thanks
Blue
Below is the difference
For the ISM-SRE-300-K9, enter:
interface ism slot/unit
For the SM-SRE-700-K9 and SM-SRE-900-K9, enter:
interface sm slot/0
For the NME-CUE, enter:
interface integrated-service-engine slot/unit
For the AIM2-CUE, enter:
interface internal-service-module slot/unit
They are just an Different type of hardware.
regards
Ronak patel
4766
