ISP SIP Trunk Issues
Hello, we are installing a new SIP trunk from our ISP to replace our PRI.  With the setup the way we have it we are getting ring no answer on inbound calls and fast busy on outbound calls.  The ISP has a Cisco 2900 router that is NATing over to our Cisco 2851 with advipservices firmware.  Behind our Cisco 2851 we have CUCM 8.0.  What could be causing our issues?  Attached is the configuration in the voice gateway.  The ISP Router has the public IP and is NATing the traffic across to 130.0.100.1.  Then there is an outbound dial-peer going to the call manager.  The phone will ring, but the calling party just hears endless ringing even if the called party picks up the phone.  I've only been testing one number since we don't have all of the numbers ported over, i have it translated with a num-exp value.  Also, it works with a phone plugged directly into an FXS port.
2 ACCEPTED SOLUTIONS
Silver
I also see the calls failing with a cause value of 21 which means that the Toll Fraud feature is blocking these calls. Here's how you configure/disable Toll Fraud on CUBE,
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Posted by WebUser Asad Raza from Cisco Support Community App
Silver
Re: ISP SIP Trunk Issues
It's just sending UDP invites out over and never gets a response.  Are you sure you have the IP address right?  Also, do they expect TCP or UDP?
Silver
Grab "debug ccsip messages" for an inbound and outbound call and attach.
Thanks for your reply.  Attached are links to two files, one is a debug ccsip all and the other is a debug ccsip messages.
For outbound calls, I'm not able to run a debug since it is a live environment.  I will try and schedule some outbound calls tomorrow to grab those debugs.
Thanks again for your help.
Joseph,
I checked your configuration attached above.. can you try to remove the below commnads under SIP section and try to make a test call??
header-passing
early-offer forced
sip-profiles 1
If it still fails, can u please share the debugs
debug voice dialpeer inout
debug ccsip all
I removed the options you suggested and I am still having the same issue with inbound calls.  Attached is the log file for an inbound call.
Silver
This looks like an ip routing / networking issue where the CUBE can reach the CUCM but the CUCM's return traffic is not reaching the CUBE (this is why the CUBE keeps sending the invites to the CUCM even when the phone is answered, the CUCM's 200 OK is not received by the CUBE). Also explains why outbound calls from CUCM fail with a fast busy.
The call manager and cube are in the same subnet.  CUBE = 130.0.100.1, CUCM = 130.0.100.146 so I'm not sure how there could be a routing or networking issue between the two devices.  Could this have anything to do with the SIP Trunk between the CUBE and CUCM not being setup properly?
Silver
I will read the documentation on this and try it out.  Thanks for your reply.
I read the documentation and setup the trusted IP list under voice services voip and it is now up and working at least on inbound calls.  I have yet to have a chance to test outbound calls but I will do that this afternoon and let you guys know if it works.  Current config is attached for future reference.  Thanks again for all of the help.
I'm still having issues with Outbound calls.  I've set this up in a CME enviroment so as not to interfere with there normal call processing.  Attached is a log of what I'm seeing with outbound calls.  Any advice is appreciated.
Silver
Did you have debug ccsip messages turned on for that call?  I don't see any SIP messaging.
Sorry I did not have ccsip messages debugging on that one.  Attached is a new debug with that enabled.
Thanks for your response.
Silver
Joseph,
This shows your SIP Trunk is trying to register and the provider is sending back a "405 Method Not Allowed".  Are you sure your carrier needs you to register your SIP Trunk?
Brian
You are correct, I don't believe they do require registration, I'm removing those options and retrying a test call.  I will post the results momentarily.
Attached are the results of the debug with the registration removed from sip-ua.
Thanks for your help.
Silver
I believe I do have the IP addresses correct for their equipment.  I'm not onsite, I'm checking now to make sure everything is powered up since this isn't running live.
Attached is the latest debug I ran.  The cabling to the Telco Router had been unplugged for some reason so that's why it wasn't communicating before on my previous debug.  I'm still getting a fast busy on outbound calls but it waits a few seconds before it gives the fast busy
VIP Super Bronze
The debug is incomplete. We only see the outbound INVITE...Pls post the full debugs
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
I'm testing on the live network now so please disregard the prevoius post.  I am getting a 503 service unavailable.  A fastbusy on outbound calls and I see no SIP traffic between my CUBE and the telco's equipment.  Below is the debug in it's entirety for the call
Sep  4 22:22:20.198: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:92566138703@130.0.100.1:5060 SIP/2.0
Via: SIP/2.0/TCP 130.0.100.146:5060;branch=z9hG4bK4051db5294
From: <2565476386>;tag=1f4823e6-e05d-4f53-ab96-a322c4ecf282-27
142664
To: <92566138703>
Date: Wed, 04 Sep 2013 22:22:20 GMT
Call-ID: 7569fb80-2271b29c-2b-92640082@130.0.100.146
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE,
NOTIFY
CSeq: 101 INVITE
Contact: <2565476386>
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <130.0.100.146:5060>;method="NOTIFY;Event=telephone-event;Duratio
n=500"
Cisco-Guid: 1969879936-0000065536-0000000043-2456027266
Session-Expires:  1800
P-Asserted-Identity: <2565476386>
Remote-Party-ID: <2565476386>;party=calling;screen=yes;privacy
=off
Max-Forwards: 70
Content-Length: 0
Sep  4 22:22:20.214: //39335/7569FB800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
142664
To: <92566138703>
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sep  4 22:22:20.226: //39335/7569FB800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
142664
To: <92566138703>;tag=32D99D64-5B5
CSeq: 101 INVITE
Reason: Q.850;cause=38
Content-Length: 0
Sep  4 22:22:20.226: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
McCartney_R1#ACK sip:92566138703@130.0.100.1:5060 SIP/2.0
142664
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
After looking at this closer, the ISP had given me an incorrect IP  address.  I corrected this and made a few dial-peer changes and calls  are now completing outbound.
Thanks all for your help with these issues.
871
