ISR 2921 Voice Gateway
Hello guys!
     Im currently implementing a CUCM 8.5 and Unity Connection 8.5 solution on a Healthcare Clinic. It will consist of a main site with two remote regions. On the main site the devices are the CUCM8.5 on an MCS, the Unity on an MCS, a Catalyst 4500 as the core switch, two Catalyst 3560X for access (IP Phones will be connecting to) and a CISCO2921-V/K9 as the gateway into the PSTN which will provide the SIP trunk. Each of the two remote regions will consist of a CISCO2901/K9 with SL-29-UC-K9 license and a Catalyst 3560X for the IP Phone connections.
The Telco will be providing a SIP trunk and I will configure the three routers as H323 gateways for the integration with the CUCM. My question is the following: How to configure the three remote routers in this scenario? Any configuration guide to H323 gateways integration with CUCM8.5? Configuration examples, guidelines and scripts will be of great help.
Also, in the switches, since the bandwith is not a problem, do you recommend configuring QoS or no Qos for the switchports?
Im new to the Uniffied Communication world. Thanks a lot guys!
  • IP Telephony
1 ACCEPTED SOLUTION
Here is a link to the h.323 configuration guide.  There is a lot of good info here on h.323.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_h323_configuration_guide/old_archives_h323/323confg.html
Here are the highligts of the last h.323/sip trunk implmentation i did.
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
(your translation rules will vary depending your needs)
voice translation-rule 9
rule 2 /\(^.*\)/ /91\1/
voice translation-rule 11
rule 1 /^[1-7]...$/ /5555555555/
voice translation-rule 91
rule 1 /^91\(..........\)/ /\1/
rule 2 /^9\(..........\)/ /\1/
rule 3 /^9011\(.*\)/ /011\1/
rule 4 /^9911/ /911/
voice translation-profile DIGITADD-9
translate calling 9
voice translation-profile DIGITSTRIP-9
translate called 91
translate redirect-called 91
(bind h.323 to an interface)
interface GigabitEthernet0/0.20
description SIP to CM H323 interface
encapsulation dot1Q 20
ip address 172.20.1.3 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip virtual-reassembly
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.20.1.3
(sccp stuff for DSP resources if you are using them)
sccp local GigabitEthernet0/0.20
sccp ccm IP OF CUCM identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 12 register MTP_DC
associate profile 10 register XCODE_DC
associate profile 11 register CONF_DC
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 11 conference
description Conference Bridge
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 12 mtp
codec g711ulaw
maximum sessions software 100
dial-peer voice 10 voip
description OUTBOUND Voice SIP calls to VzB
translation-profile outgoing DIGITSTRIP-9
destination-pattern 9T
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte digit-drop
no vad
dial-peer voice 20 voip
description INBOUND Voice SIP calls from VzB
incoming called-number .
voice-class codec 1
no vad
dial-peer voice 21 voip
description to CM from Gateway
translation-profile outgoing DIGITADD-9
destination-pattern
session target ipv4:ip address of cm
voice-class codec 1
no vad
dial-peer voice 11 voip
description voip dial peer to Verizon
destination-pattern 9911
voice-class codec 1
no vad
dial-peer voice 911 voip
destination-pattern 911
voice-class codec 1
no vad
dial-peer voice 111 voip
description voip dial peer to Verizon international
destination-pattern 9011T
voice-class codec 1
no vad
(This is the SIP information you get from your provider regarding the registar and server they provide you.)
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry options 1
registrar ipv4:172.xxx.xxx.164 expires 3600
sip-server ipv4:172.xxx.xxx.49:5091
g729-annexb override
I would always do qos.  You could probley get away with using Cisco's auto qos feature unless you have other traffic to account for.
on the switch ports:
auto qos voip  cisco-phone
On the trunk ports:
auto qos voip trust
Here is some info on auto qos:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/auto_qos.html
I hope this helps.
James
voice service voip
h323
sip
  early-offer forced
voice class codec 1
voice class h323 1
translate calling 9
translate called 91
no ip redirects
no ip proxy-arp
ip nat inside
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 4
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
codec g711ulaw
voice-class codec 1
no vad
voice-class codec 1
no vad
destination-pattern
voice-class codec 1
no vad
voice-class codec 1
no vad
voice-class codec 1
no vad
voice-class codec 1
no vad
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry options 1
On the trunk ports:
auto qos voip trust
I hope this helps.
James
Excellent James. Thanks a lot! Great material.
2761
