Community Member
ISR 3825 + 2811 T38 issue
I trying to get Fax over IP using T.38 properly running.
I have a CCM 4.1.3 with a Fax server connected via a trunk. The fax to external PSTN are working when I send them to the H323 gateway. The problem now it only works if the gateway is a 3725 or a 3745. When I try to use a 2811 or a 3825 it doesn't work. The fax connection gets established but after exactly 20 seconds (and it is always 20 seconds, so looks like a timeout timer) the connection gets dropped and fax never arrives.
On the all the router the configuration is similar:
voice service pots
fax rate disable
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711ulaw
Actually the configuration shouldn't be so complecated as the fax is only outgoing to the PSTN. Also I tried different IOS version ranging from 12.3 to 12.4.
So now I am out of ideas, so your input is desperately waited for.
Thanks for the help in advance.
Best regards,
Andreas Plaul
Community Member
Re: ISR 3825 + 2811 T38 issue
Andreas, your config is incorrect if you are trying (And you should) to use T.38. See the attached. you should also look at XMediusFAX from Sagem-Interstar as a great fax solution for your company. It is a robust T.38 software only product, no need for fax boards in the server and it leverages the Cisco infrastructure with T.38. Information available in partner central. It is a CTDP certified product.
Community Member
403
