ISR and UCS description & configuration
Hi ,
Carrying on from my previous post, i would really appreciate if some one kindly throw some light on the specifications of ISR and UCS and the configurations usually supproted on them and all the descriptive stuff about the same, i am preparing for these topic ( specially the former one, which is completely new to me ) and would love to have some correct and precise info on the forum !
Whatever level you reach getting better never stops -- Sachin Tendulkar
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Search for SRND - relevant to the product you want to learn about.
As Paolo says, review SRNDs or just search CCO for the product you're interested to get documentation.
If you want to review and understand virtualization (UC on UCS) then go to the virtualizacion wiki:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
For ISRs, there's plenty of material on anything you can configure on them, just search CCO.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Hall of Fame Super Red
Hey Abhishek,
Check out this awesome video from CNC's Bill Bell
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/unified-comm-application?view=video
Cheers!
Rob
Hi Rob,
Thanks a Ton !
235
