05-04-2012 06:40 AM - edited 03-16-2019 10:59 AM
I would like to say how to do a DIAL-PEER VOICE that are validated only if ALL MATCH CRITERA is OK.
like:
dial-peer voice 1000 voip
destination-pattern 118050001
incoming called-number 118050001
I have search in the CIsco docuemntation and open a TAC case, but for the momnet i have no reply if this is possible.
All help are welcome.
Regard.
05-04-2012 07:01 AM
AFAIK it's not possible, you only match one condition.
The router selects an inbound dial peer by matching the information elements in the setup message with the dial peer attributes. The router attempts to match these items in the following order:
1. Called number with the incoming called-number command
2. Calling number with the answer-address command
3. Calling number with the destination-pattern command
4. Incoming voice port with the configured voice port
The router must match only one of these conditions. It is not necessary for all the attributes to be configured in the dial peer or that every attribute match the call setup information; only one condition must be met for the router to select a dial peer. The router stops searching as soon as one dial peer is matched and the call is routed according to the configured dial peer attributes. Even if there are other dial peers that would match, only the first match is used.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-04-2012 07:15 AM
Thanks you for fast reply.
Effectivelly, i have see that call flow in cisco documentation , but i would like to ask the community if someone have a 'tips'.
Too bad, how do multi-matching dial-peer like with CUBE if this basic functionality is not implemented ?..i'm afraid about that ; this fucntion is very basic.
Regard
