Issue adding a 2nd PRI
I'm having an issue adding a 2nd PRI. I'm guessing it's something obvious and I'm hoping a fresh pair of eyes can pick out the issue.  The PRI on 0/0/0 works fine but the PRI on 0/0/1 continually flips between AWAITING_ESTABLISHMENT and TEI_ASSIGNED.  Here are the relevant parts of the config along with the "sh isdn status".  I ran the "sh isdn status" twice to show it in both states.
version 15.2
hostname PRI-GW
card type t1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
isdn switch-type primary-ni
voice-card 0
voice translation-rule 1
rule 1 /55555\(.....\)/ /\1/
voice translation-profile STRIP
translate called 1
hw-module pvdm 0/0
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/0/1
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:23
translation-profile incoming STRIP
voice-port 0/0/1:23
Show ISDN Status:
PRI-GW#sh isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        2 Active Layer 3 Call(s)
        CCB:callid=286D, sapi=0, ces=0, B-chan=1, calltype=VOICE
        CCB:callid=286F, sapi=0, ces=0, B-chan=2, calltype=VOICE
    Active dsl 0 CCBs = 2
    The Free Channel Mask:  0x807FFFFC
    Number of L2 Discards = 0, L2 Session ID = 1
ISDN Serial0/0/1:23 interface
        dsl 1, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 146
    Total Allocated ISDN CCBs = 2
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
        CCB:callid=2870, sapi=0, ces=0, B-chan=3, calltype=VOICE
    Active dsl 0 CCBs = 3
    The Free Channel Mask:  0x807FFFF8
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
    Number of L2 Discards = 0, L2 Session ID = 147
    Total Allocated ISDN CCBs = 3
Everyone's tags (3)
Thought I'd add the "debug isdn q921 info:
*Oct 30 22:19:35.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:19:35.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:36.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:37.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:38.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:44.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:19:44.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:45.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:46.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:47.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:53.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:19:53.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:54.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:55.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:19:56.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:02.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:20:02.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:03.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:04.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:05.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:11.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:20:11.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:12.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:13.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:14.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:20.448: ISDN Se0/0/1:23 Q921: L2_EstablishDataLink: sending SABME
*Oct 30 22:20:20.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:21.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:22.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
*Oct 30 22:20:23.448: ISDN Se0/0/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
Green
Your debug q921 is clearly showing you are not receiving layer2 frames
either sabmes or uas from your service provider.
Contact the SP it looks like they have not activated their end.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
237
