Issue FXO
bsaid1977
hi,
i have call manager 6.1 with a H323 gateway.
in the gateway i have 3 cards:
- one PRI : the calls work hine ( in and out)
- one card 4-Fxo: with 4 analog line : calls work fine (in and out)
- one card 4-fxo: with 4 gateway GSM: calls from site to outside work fine. but the call from outside dosn't work, the phone rings and when i tray to respond the call hang up :
this the config for the 4 voice port:
voice-port 0/3/0
input gain -3
output attenuation 4
echo-cancel coverage 24
no comfort-noise
cptone FR
timeouts interdigit 6
timeouts call-disconnect 5
timing hookflash-out 500
connection plar opx 100
impedance complex2
caller-id enable
Can you try "no battery reversal" ?
If still problem, get "debug vpm signal" with "term mon" for a failed call.
16 Replies 16
dennisbehrens
Level 4
Level 4
If the call rings properly, but answering causes a disconnect, this usually indicates a codec problem. Can you please post your dial-peers?
thanks for replay
yes the ring is good, but tha call disconnect when i tray to answeer
the problem is with port 0/3/X
this my all dial peer:
dial-peer voice 100 voip
destination-pattern ...
session target ipv4:172.16.0.254
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 10 pots
destination-pattern 82..........
direct-inward-dial
port 0/0/1
dial-peer voice 11 pots
destination-pattern 83..........
incoming called-number 0522335486
direct-inward-dial
port 0/0/2
dial-peer voice 12 pots
destination-pattern 84..........
incoming called-number 0522972486
direct-inward-dial
port 0/0/3
dial-peer voice 9 pots
destination-pattern 81..........
direct-inward-dial
port 0/0/0
dial-peer voice 1 pots
destination-pattern 9..........
direct-inward-dial
port 0/2/0:15
forward-digits 10
dial-peer voice 125 pots
destination-pattern 7.............
direct-inward-dial
port 0/2/0:15
forward-digits 13
dial-peer voice 126 pots
destination-pattern 800...
direct-inward-dial
port 0/2/0:15
forward-digits 3
dial-peer voice 127 pots
destination-pattern 80..
direct-inward-dial
port 0/2/0:15
forward-digits 2
dial-peer voice 20 pots
destination-pattern 86..........
port 0/3/0
dial-peer voice 21 pots
destination-pattern 87..........
port 0/3/1
dial-peer voice 22 pots
destination-pattern 88..........
port 0/3/2
dial-peer voice 23 pots
destination-pattern 89..........
port 0/3/3
Try:
voice-port x/y
no supervisory disconnect signal
note, if you use trunk-groups, you can reduce the many DPs to a single one.
yes, i have the same config for both card 4-FXO
the first 4 port is connected to 4 analog lines (to telecom company) and all call are fine from inside to outside and from outside from inside.
but the seconde card 4-FXO are connected to 4 gateway GSM (to mobile phone company), i can make the call from inside to other number in the world, but i can't receive the call( just ring and han up when i tray to respond.
Have you tried plugging the GSM Gateway lines into the other ports to isolate that it's not the FXO ports?
I've corrected my reply above, try and let us know.
hi,
this command is to solve another problem, but i have testd this command without result.
yes i have tested the port 0/3/X , they work fine with analog line.
And if the port isn't good i can't make calls from inside to outsider vis this ports.
thanks for advice
Are the ports from your GSM Gateway Ground Start?
the company phone says that,
how i can use loop Start
Loop start is default.
Ground start is not used outside north america.
i have read the document: Document ID: 8120
i used all command in this document, but issue doesn't mutch with this trooblshoot document.
thanks for your best effort
Nobody said that you have a disconnect supervision problem.
Please collect the debug indicated above.
hi,
i attached the debug file
thanks for help
