Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Issue headset for ip phone 7962
I have problems with a headset plantronics HW251N attached to a cisco 7962G, i cant transfer call's when the user answer a call with the headset, i can't transfer the call's, on the phone screen does not appear the option transfer.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Alan, I'll just add this
Hi Alan,
I'll just add this note to the good advice from my friend Java (+5 Java-man!)
If you are running the firmware listed below it may be this bug and you would need to get the "fixed-in" firmware version from TAC;
Problems transferring/answering calls when using headset with 79XX phone
CSCun26289
Symptom:
- When a user attempts to transfer a call, the original call is placed on hold, but the user is not able to dial the transfer destination.
- When a user already has an active call on their phone, they are unable to answer a new incoming call. The original call is placed on hold, and the new call is simply disconnected.
Conditions:
- Using a headset with a 7900 series phone
- Running firmware 9.3(1)SR4
Workaround:
- Do not use a headset
- Rollback to 9.3(1)SR3 or earlier
Known Fixed Releases:
(1)
9.3(1)ES27
Cheers!
Rob
You probably want to open a
You probably want to open a TAC on that for further investigation.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Alan,
CSCun26289
Symptom:
Conditions:
Workaround:
(1)
9.3(1)ES27
Cheers!
Rob
Yes, you're right, the phone
Yes, you're right, the phone has that version of fw.
I'm gonna to change it.
Thanks.
Hi Rob! I did the rollback to
Hi Rob!
I did the rollback to 9.3 the tranfer action work perfectly, but now another bug appear, when the phone receive a call the led of the line who receive the call does not blink.
Did you see this behavior before ?
Cheers
Hi Rob!Problem Solved !!! I
Hi Rob!
Problem Solved !!! I just only delete the other fw from the flash, no create and create cnf files and everything fine!!!
Thnks a lot.
Regards.
1693
