Issue on Inbound E1 R2
Hello Guys,
Could anyone help me on the issue below?
I am getting a cause value disconnect 21, on ISDN is considered as toul fraud, however on R2 digital I could not find out what this cause means, anyone has detected this issue before?
Jun 16 12:35:45.092: //-1/92263D968830/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=3
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=99993303
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 16 12:35:45.092: //-1/92263D968830/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x68F5D940, Call Info(
   Calling Number=,(Calling Name=)(TON=Network, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=99993303(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1500, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jun 16 12:35:45.092: //-1/92263D968830/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Network, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Network, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Jun 16 12:35:45.092: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 16 12:35:45.092: :cc_get_feature_vsa malloc success
Jun 16 12:35:45.092:  cc_get_feature_vsa count is 42
Jun 16 12:35:45.092: :FEATURE_VSA attributes are: feature_name:0,feature_time:1906008448,feature_id:1299
Jun 16 12:35:45.092: //1299/92263D968830/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Network, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=99993303(TON=Unknown, NPI=Unknown))
Jun 16 12:35:45.092: //1299/92263D968830/CCAPI/cc_process_call_setup_ind:
   Event=0xC0488640
Jun 16 12:35:45.096: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 99993303
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/ccCallSetContext:
   Context=0x71A78100
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1299 with tag 1500 to app "_ManagedAppProcess_Default"
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=1001, Params=0x71A67390, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/ccCheckClipClir:
   Destination Pattern=9999[1-7]..., Called Number=99993303, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=92263D96-F489-11E3-8830-AA461CC4151C, Outgoing Dial-peer=1001
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=3
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=99993303
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jun 16 12:35:45.096: //1299/92263D968830/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0xC03606F0, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Network, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=99993303(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 16 12:35:45.096: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 16 12:35:45.096: :cc_get_feature_vsa malloc success
Jun 16 12:35:45.096:  cc_get_feature_vsa count is 43
Jun 16 12:35:45.100: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 16 12:35:45.100: :FEATURE_VSA attributes are: feature_name:0,feature_time:1906007328,feature_id:1300
Jun 16 12:35:45.100: //1300/92263D968830/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jun 16 12:35:45.100: //1300/92263D968830/CCAPI/ccCallSetContext:
   Context=0x71A67340
Jun 16 12:35:45.100: //1299/92263D968830/CCAPI/ccSaveDialpeerTag:
Jun 16 12:35:45.116: //1300/92263D968830/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Jun 16 12:35:45.116: //1300/92263D968830/CCAPI/cc_api_call_proceeding:
   Interface=0xC03606F0, Progress Indication=NULL(0)
Jun 16 12:35:45.172: //1300/92263D968830/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0xC03606F0, Call Id=1300
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
Jun 16 12:35:45.172: //1299/92263D968830/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jun 16 12:35:45.172: //1300/92263D968830/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1300
Jun 16 12:35:45.172: //1300/92263D968830/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Jun 16 12:35:45.172: //1300/92263D968830/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jun 16 12:35:45.176: //1300/92263D968830/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC03606F0, Tag=0x0, Call Id=1300,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jun 16 12:35:45.176: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 16 12:35:45.176: :cc_free_feature_vsa freeing 719B5D18
Jun 16 12:35:45.176:  vsacount in free is 42
Jun 16 12:35:45.176: //1299/92263D968830/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1002, Params=0x71A6B1D0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jun 16 12:35:45.176: //1299/92263D968830/CCAPI/ccCheckClipClir:
   Guid=92263D96-F489-11E3-8830-AA461CC4151C, Outgoing Dial-peer=1002
Jun 16 12:35:45.176: //1299/92263D968830/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=3
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=99993303
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
I really appreciated any help!
Best regards,
Marcos Cardoso
Marco,Are you running Cisco
Marco,
Are you running Cisco IOS 15.1(2)T? If so, have you  verified the trust list?
A new feature has been introduced in Cisco IOS® Software Release 15.1(2)T to guard against the incidence of toll-fraud on Voice GateWays (VGWs) installed with Cisco IOS. Starting with IOS 15.1(2)T and newer releases of IOS based on this version, the toll-fraud prevention settings are the default behavior of Cisco IOS-based VGWs.
The purpose of this document is to raise awareness of this new feature, as upgrading to this release will require additional configuration to permit certain types of voice calls to be placed and route to completion. It is important to note that upgrading to 15.1(2)T will block all inbound VoIP call setups until the VGW is properly configured to trust these sources. Any plans to upgrade to releases with this feature must include extra steps to configure trusted VoIP hosts after the upgrade in order for calls to route successfully. Additionally, two-stage dialing is no longer enabled by default with this release.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
Yosh
HTH Regards, Yosh
Hi Yosh, Firstly, thank you
Hi Yosh,
Firstly, thank you for you reply.
I am running IOS 15.1(4)T as you can see on the following command:
sh ver
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 15.1(4)M5, REL        EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 17:25 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
R3-ARBUE-2548-01-VGW-01 uptime is 2 days, 14 hours, 49 minutes
System returned to ROM by reload at 20:20:59 ARBUE Fri Jun 13 2014
System restarted at 20:23:06 ARBUE Fri Jun 13 2014
System image file is "flash:c3825-spservicesk9-mz.151-4.M5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 1010688K/37888K bytes of memory.
Processor board ID FTX1236A3Q3
2 Gigabit Ethernet interfaces
8 Channelized E1/PRI ports
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO3825
I've had a ICT between my cluster. we are using only one gateway to delivery those calls. However I have 2 E1 delivering calls and only has stopped to work. Both of them are the same Service Provider, and the first one has stopped last week. Nothing was changed. I've already reset the ICT trunk in both sides and restarted the gateway as well. Nothing worked out.
Have you any idea?
Marcos Cardoso
77
