Issue updateing firm ware on a 7942 phone
Hello All,
I am working for a company that is purchasing refurbished 7942 phones for their system  Several of the phones have firmware that is two old and cannot be upgraded to the current ccm version.  I am not allowed (company policy) to install an older version on CCM so I am using tftp on a cisco 881 router to do the upgade to the jumper version that will allow me to up grade on ccm.
Current config on router
Current configuration : 2048 bytes
! Last configuration change at 16:18:38 UTC Thu Feb 6 2014
! NVRAM config last updated at 16:18:40 UTC Thu Feb 6 2014
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp pool vlan 2
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FTX153381AE
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
ip forward-protocol nd
no ip http server
no ip http secure-server
tftp-server cnu41.8-4-0-79.sbn
tftp-server cvm41sccp.8-4-0-79.sbn
tftp-server dsp41.8-4-0-79.sbn
tftp-server jar41sccp.8-4-0-79.sbn
tftp-server SCCP41.8-4-1S.loads
tftp-server term41.default.loads
tftp-server apps41.8-4-0-79.sbn
tftp-server cmterm_7936.3-3-20-0.bin
tftp-server XMLDefault.cnf.xml
tftp-server XMLDefault_polycom.cnf.xml
tftp-server SEP0004f2e246cd.cnf.xml
tftp-server SEP0004f2e246cd_polycom.cnf.xml
tftp-server flash:apps42.8-5-3ES4.sbn
tftp-server flash:cnu42.8-5-3ES4.sbn
tftp-server flash:cvm42sccp.8-5-3ES4.sbn
tftp-server flash:dsp42.8-5-3ES4.sbn
tftp-server flash:jar42sccp.8-5-3ES4.sbn
tftp-server flash:SCCP42.8-5-3SR1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
end
Cisco IOS version -> Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
If I hook up the phone to the router and have not done a factory reset I get the following log:
Feb  6 15:15:17.959: TFTP: Looking for CTLSEP0023EBC81FB8.tlv
Feb  6 15:15:18.027: TFTP: Looking for SEP0023EBC81FB8.cnf.xml
Feb  6 15:15:18.071: TFTP: Looking for XMLDefault.cnf.xml
Feb  6 15:15:18.071: TFTP: Opened flash:XMLDefault.cnf.xml, fd 0, size 3814 for process 269
Feb  6 15:15:18.083: TFTP: Finished flash:XMLDefault.cnf.xml, time 00:00:00 for process 269
Feb  6 15:15:24.547: TFTP: Looking for cmterm_7936.3-3-20-0.loads
Feb  6 15:15:39.023: TFTP: Looking for CTLSEP0023EBC81FB8.tlv
Feb  6 15:15:39.079: TFTP: Looking for SEP0023EBC81FB8.cnf.xml
Feb  6 15:15:39.131: TFTP: Looking for XMLDefault.cnf.xml
Feb  6 15:15:39.131: TFTP: Opened flash:XMLDefault.cnf.xml, fd 0, size 3814 for process 269
Feb  6 15:15:39.143: TFTP: Finished flash:XMLDefault.cnf.xml, time 00:00:00 for process 269
Feb  6 15:15:40.455: TFTP: Looking for English_United_States/mk-sccp.jar
Feb  6 15:15:40.551: TFTP: Looking for United_States/g3-tones.xml
The phone hangs at the last line then reboots to start the process again.   I am also wondering why it is looking for
cmterm_7936.3-3-20-0.loads instead of the 7942 loads.
If I do a factory reset prior to the upgrade attempt I get the following event log.  (phone is in the upgrade screen during this)
Feb  6 16:59:53.559: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
Feb  6 16:59:54.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
Feb  6 17:00:22.579: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to up
Feb  6 17:00:31.931: TFTP: Looking for term42.default.loads
Feb  6 17:00:31.935: TFTP: Opened flash:term42.default.loads, fd 0, size 662 for process 269
Feb  6 17:00:31.935: TFTP: Finished flash:term42.default.loads, time 00:00:00 for process 269
Feb  6 17:00:33.259: TFTP: Looking for term42.default.loads
Feb  6 17:00:33.259: TFTP: Opened flash:term42.default.loads, fd 0, size 662 for process 269
Feb  6 17:00:33.263: TFTP: Finished flash:term42.default.loads, time 00:00:00 for process 269 Feb  6 16:59:53.559: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
The phone then reboots hangs for several minutes than repeats with the same event logs.  .
Any help that can be offered would be greatly appreciated.
Thank you
John
Remove the following:
Paste the following:
tftp-server flash:apps42.8-5-3ES4.sbn alias apps42.8-5-3ES4.sbn
tftp-server flash:cnu42.8-5-3ES4.sbn alias cnu42.8-5-3ES4.sbn
tftp-server flash:cvm42sccp.8-5-3ES4.sbn alias cvm42sccp.8-5-3ES4.sbn
tftp-server flash:dsp42.8-5-3ES4.sbn alias dsp42.8-5-3ES4.sbn
tftp-server flash:jar42sccp.8-5-3ES4.sbn alias jar42sccp.8-5-3ES4.sbn
tftp-server flash:SCCP42.8-5-3SR1S.loads alias flash:SCCP42.8-5-3SR1S.loads
tftp-server flash:term42.default.loads alias term42.default.loads
tftp-server flash:term62.default.loads alias term62.default.loads
Yosh
HTH Regards, Yosh
Hall of Fame Super Red
Hi John,
Just one small note to add to the good tips from my friend Yosh (+5)
It's quite possible that if the 7942's are running an old firmware that it
may be too old of a load to move directly to 8.5(3) as well. I would try 8-3-3
or 8-4-x as an interim step
Firmware Upgrade Issues for SCCP
Note  For all SCCP firmware upgrades from firmware release versions earlier  than 8.3(3) to version 8.5(3) or greater, you must first upgrade your  firmware to version 8.5(2). Once you have upgraded to version 8.5(2),  you can upgrade your IP Phone to version 8.5(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html#wp57602
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
That's good stuff. +5 Rob
Yosh
HTH Regards, Yosh
Re: Issue updateing firm ware on a 7942 phone
I have tried what you have suggested and got the following results.
Phone without factory reset.   firmware - 8-3-2-27  no apparent change
Feb  7 16:32:37.425: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
Feb  7 16:32:38.425: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
Feb  7 16:33:06.445: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to up
Feb  7 16:33:10.285: TFTP: Looking for CTLSEP081FF3621B99.tlv
Feb  7 16:33:10.345: TFTP: Looking for SEP081FF3621B99.cnf.xml
Feb  7 16:33:10.393: TFTP: Looking for XMLDefault.cnf.xml
Feb  7 16:33:10.397: TFTP: Opened flash:XMLDefault.cnf.xml, fd 0, size 3814 for process 169
Feb  7 16:33:10.405: TFTP: Finished flash:XMLDefault.cnf.xml, time 00:00:00 for process 169
Feb  7 16:33:17.317: TFTP: Looking for cmterm_7936.3-3-20-0.loads
Feb  7 16:33:32.549: TFTP: Looking for CTLSEP081FF3621B99.tlv
Feb  7 16:33:32.649: TFTP: Looking for SEP081FF3621B99.cnf.xml
Feb  7 16:33:32.697: TFTP: Looking for XMLDefault.cnf.xml
Feb  7 16:33:32.697: TFTP: Opened flash:XMLDefault.cnf.xml, fd 0, size 3814 for process 169
Feb  7 16:33:32.709: TFTP: Finished flash:XMLDefault.cnf.xml, time 00:00:00 for process 169
Feb  7 16:33:34.361: TFTP: Looking for English_United_States/mk-sccp.jar
Feb  7 16:33:34.529: TFTP: Looking for United_States/g3-tones.xml
Phone with factory reset - firmware  8-3-1-22 - I tried 3 phones.  2 with unknown firmware as the phone had already been factory reset and onwe with the firmware listed above.  1 had one of the unknown phones work the other two are giving me the events listed below and then reboots for the same process.
Feb  7 17:07:22.289: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
Feb  7 17:07:50.305: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to up
Feb  7 17:07:59.677: TFTP: Looking for term42.default.loads
Feb  7 17:07:59.677: TFTP: Opened flash:term42.default.loads, fd 0, size 662 for process 169
Feb  7 17:07:59.681: TFTP: Finished flash:term42.default.loads, time 00:00:00 for process 169
Feb  7 17:08:00.989: TFTP: Looking for term42.default.loads
Feb  7 17:08:00.993: TFTP: Opened flash:term42.default.loads, fd 0, size 662 for process 169
Feb  7 17:08:00.993: TFTP: Finished flash:term42.default.loads, time 00:00:00 for process 169 Feb  7 17:07:22.289: %
Once the phone has started the factory reset (upgrading process) is there a way that check the firmware.  Also I am not sure if it matter.  The phones were all set maunally to enable 802.1x.  Do I need to disable that prior to starting the firmware upgrade.  I found the phone that did work had that feature disabled after it came back up.
Thank you
John
It seems that if I disable 802.1x anything 8-3-2-27 and newer will work with a factory reset.  Anything older still does not work and all phones that have not had a factory reset will not upgrade.
So the process that I am using now is:
Disable 802.1x from the phone.
Verifiy the firmware (needing 8-3-27 or newer)
Factory reset.
Phone works.
So given this I should be able to get most all my phones up.  However there have been a couple phones that had a factory reset done on them prior to me figuring out the above.  Does anyone know how to pull the settings so I can change the 802.1x settings after the phone has started the upgrade process?
982
