Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
# issue with E1
Dear Friends,
I'm facing an issue, when I dial the DID of the call centre and trying to insert # as input (as menu ask to insert # to repeat the menu) I got message (which uploaded in case of customer time out without input) telling plz insert choice, which means that the system not accepting # as button, however all the digits is working fine including *
Any idea? appreciate your support as usual
Mohamed Gheta
Re: # issue with E1
Please not that I'm not getting this issue in case of analog lines
Hall of Fame Super Gold
Re: # issue with E1
please send "show controllers e1".
Re: # issue with E1
Dear Freind,
As per your advice, I attached the requested result
Wish to hear from you soon,
Have a nice day,
Mohamed
Re: # issue with E1
Circuit is clean.
Sorry, I don't know what to suggest.
Re: # issue with E1
Thanks so much for your concern, no problem, I will keep searching
Have a nice day,
Mohamed
Re: # issue with E1
Have you got the dtmf-relay rtp-nte h245-signal h245-alphanumeric command configured under your voip dial-peer ?
Re: # issue with E1
Hi Friend,
Actually I'm using ;
dtmf-relay h245-alphanumeric
As I'm using R2 not ISDN PRI
So you recommend to use this instead
Mohamed
153
