issue with embedded-Service-Engine 0/0
Hi all
try to setup CUE in 2951 router, on  embedded-Service-Engine 0/0  interface, type command  # "service-module enable" and encount following error:
Memory size does not meet the requirements of Embedded-Service-Engine 0/0
Physcially this moduel come with 4GB ram, and I know the mimimum requirement for thsi to work is 1 GB.
show diag:
Embedded Service Engine 0/0 :
  Total platform memory : 1048576K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x20000000
  Number of blocks of memory for 2nd core : 1
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
  Any suggestion?
thanks in advance
Roy
Hall of Fame Super Gold
The interface you're trying to use, leave it shutdown. You will use interface ISM0/0.
And, do the CUE installation from the CUE console directly, as it works much better.
Hi Paolo,
Can you explain it more? I'm experiecing similar issue with Cisco  2921.
Are you saying leave the embedded service engine0/0 shutdown and configure IP on ISM0/0 module and make a session to ISM 0/0 ?
Raj
I find a doc on following link, which explains all:
http://2and2is5.wordpress.com/2011/02/17/guide-to-installing-cisco-ucs-express/
ADD 1 GB DRAM to run an embedded service engine.
Embedded Service Engine Minimum Memory Requirement
1 GB
1.5 GB
2 GB
Cisco 2911
Cisco 2951
Cisco 3925
Cisco 2921
Cisco 3945
Again, EM0/0 has nothing to do with CUE, there is no need for addtional memory, read post above.
Hi Paolo,
In 2800 or 3900 to enable CUE we use the below command:
interface Service-Engine1/0
 ip unnumbered FastEthernet0/0
 service-module ip address a.3.229.128 255.255.0.0
 service-module ip default-gateway a.3.229.1
For  2900 or 3900 when I try the the below CLI it is not working ?, please light me the right procedure to enable CUE on 2900 series.
error encounter as:
Re: issue with embedded-Service-Engine 0/0
Use ism 0/0 instead of embedded service engine. Use the same command under ism interface.
Dheeraj
Thanks for the reply.
So under ism 0/0 we need to configure the CUE basic configuration. To access the CUE module for voicemail configuration I need to configure as below.
cisco# service-module  embedded-Service-Engine 0/0 session
Please correct me if my understanding is wrong ?
Did anyone figure this out.... I have the same issue with a 2921 and the suggestion to use ISM does not work. The router only has an option for the Embedded Service Engine....
If I ordered a 2921 with CUE I would expect it to come with enough memory to have the CUE work.
Hi Heath Freel
Are you able to figure this out.. I have the same problem with my 2921 and it does not have ISM.
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 10.250.16.2     YES NVRAM  up                    down
GigabitEthernet0/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1         10.250.16.2     YES NVRAM  up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
interface GigabitEthernet0/1
ip address 10.250.16.2 255.255.255.0
ip helper-address 10.131.4.2
duplex auto
speed auto
interface Embedded-Service-Engine0/0
ip unnumbered GigabitEthernet0/1
service-module ip address 10.250.16.3 255.255.255.0
service-module ip default-gateway 10.250.16.2
ip route 10.250.16.3 255.255.255.255 Embedded-Service-Engine0/0
Sh diag
  Total platform memory : 524288K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
Router#service-module embedded-Service-Engine 0/0 status
Service Module is Cisco Embedded-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module heartbeat-reset is enabled
Embedded Service Engine boot state is RESET
No install/uninstall in progress
Router#
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Any help really appreciate..
If "show diag" does not show an ISM module but you know that one is present, either the module is not correctly installed (try reseating in connectors), or it is faulty and need to be RMA.
All,
I do have the same problem. Can any one help me out?
8000
