issue with extension mobility
when user tries to login into EM services , they are getting an error as " login unsuccessful (7) unknown error " . they are successfully logged int but every this error is displayed . i have restarted EM services it was working fine for 2 days today again this error flashed out .
CUCM 8.6.2
1 ACCEPTED SOLUTION
Hello!http://software.cisco
Hello!
http://software.cisco.com/download/release.html?mdfid=283782839&flowid=45898&softwareid=282074295&release=8.6(2a)SU4a&relind=AVAILABLE&rellifecycle=&reltype=latest
only if you have contract...
VIP Purple
Hi, could be the bug When
could be the bug
When logging into extension mobility gets Login unsuccessful Unknown 7
CSCtz28748
Known Affected Releases:
(2)
8.0(3)
8.6(2.22025.1)
regds,
aman
Hi ,Thanks for quick response
Hi ,
Thanks for quick response , solution specified was to restart services . i have done it but no use .
VIP Purple
Hi, are u using the same CUCM
are u using the same CUCM version as mentioned in bug?
please share show version active.
regds,
aman
Active Master Version: 8.6.2
Active Master Version: 8.6.2.21900-5
Hello,You may try to restart
You may try to restart Tomcat also, but it will help for a short time.
Permanent fix is to upgrade to 8.6.2.22900.9
Kirill
Hello , Tried with tomcat
Hello ,
Tried with tomcat restart but no use , may we should update  .Any link for update ...
Hello!
VIP Purple
As suggested by Kirill ,
As suggested by Kirill , please try upgrading the CUCM.
Make sure you have valid ESW contract as well in case of any assistance required while doing upgrades, if TAC case needs to b opened.
regds,
aman
123
