Issue with FAC
kumar3880
Hi all
We have a CUCM 6.0 configured and there are about 60 FAC's created in it.Now any FAC that is created newly is not working and the codes that were created earlier is working fine.
Are there any bugs or any services to be checked.....do let me know......
regards
kumar
gogasca
Level 10
Level 10
Not sure what is happening, if you delete a working code, and re-add it using same AUth level? What happens?
If you want root case we will need CUCM
DBMon
DBNotify
CCM SDI
CCM SDL
And check replication is ok.
You can restart CUCM service if config is correct to force a re-read from DB.
