Community Member
Issue with FAST DIAL not Speed Dial
I have a Cisco IP Phone 7965 in full working condition. Its is registered to CCM successfully.
I logged into extension mobility and I also logged into Personal Fast Dial Successfully.
Now to make a fast dial I have to hit >> directories >> personal Directories>> personal fast dials>>  and then i hit fast dial and call routes successfully.
But every time i want to access fast dial do i have to go through all the above process which consumes more time and effort.
Is there a soft key that can be configured or a code (eg: like **# ect) to go to personal fast dials and make call easily.
No, you cannot configure
No, you cannot configure softkeys, you can only choose from the ones available, and no, we have no codes to bring menus or anything like that.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Thank you Jaime for your
Thank you Jaime for your answer.
95
