Issue with Fax machine receiving fax from SIP Gateway
We have a fax machine on an mgcp controlled vg 224 and it is has severe issue receiving faxes that come in from the PSTN.
Flowpath:
PSTN -> 2851 GW PRI circuit ->SIP Trunk from GW to CUCM 7.1.3 -> MGCP controlled VG 224 using g711 passthur, T38 inhibited, to a Fax machine.
Note, voice calls seem fine when testing with an analog handset.
debug ccsip messages shows the following:
*Apr 13 18:21:21.729: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Internal Server Error
The topology is there are two Gateways for this site and each has a SIP Trunk to CUCM. IP's ending in .220 for one and .221 for the second gateway.
Inbound calls come in a PRI on the .221 Note: each router has a PRI, one gets local, the other gets LD and INTL, dial-peers are sip -h323.
It appears to me that the two SIP Trunks are causing an issue with this one fax machine, it appears the internal server error is due to calls getting routed based on both the .20 and the .221 which is causing a routing issue, it seems,, which is odd as other faxes on other Vg 224's at same site seem to be working fine. There at least two faxes on this same VG having this issue. Short debug follows:
Sent:
INVITE sip:62993@xx.xx.169.220:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.169.221:5060;branch=z9hG4bK23A171145
Remote-Party-ID: <sip:xxx3869800@xx.xx.169.221>;party=calling;screen=no;privacy=off
From: <sip:xxx3869800@xx.xx.169.221>;tag=5546D6C-1154
To: <sip:62993@xx.xx.169.220>
Date: Fri, 13 Apr 2012 18:21:21 GMT
Call-ID: 4E1FF68C-84CC11E1-91ABBA4D-E011E85F@xx.xx.169.221
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1310557676-2227966433-2166947865-806423056
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1334341281
Contact: <sip:xxx3869800@xx.xx.169.221:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 333
v=0
o=CiscoSystemsSIP-GW-UserAgent 2441 307 IN IP4 xx.xx.169.221
s=SIP Call
c=IN IP4 xx.xx.169.221
t=0 0
m=audio 16748 RTP/AVP 0 18 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
*Apr 13 18:21:21.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Fri, 13 Apr 2012 18:22:03 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Apr 13 18:21:21.701: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:62993@xx.xx.169.221:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.169.220:5060;branch=z9hG4bK1651C4A8
Remote-Party-ID: <sip:xxx3869800@xx.xx.169.220>;party=calling;screen=no;privacy=off
From: <sip:xxx3869800@xx.xx.169.220>;tag=54FBAF8-1C26
To: <sip:62993@xx.xx.169.221>
Call-ID: 674FB818-84CC11E1-B3FC93ED-99EDEFF2@xx.xx.169.220
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1334341323
Contact: <sip:xxx3869800@xx.xx.169.220:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 334
v=0
o=CiscoSystemsSIP-GW-UserAgent 1765 2391 IN IP4 xx.xx.169.220
s=SIP Call
c=IN IP4 xx.xx.169.220
t=0 0
m=audio 17586 RTP/AVP 0 18 100 101
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
*Apr 13 18:21:21.717: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Sent:
Via: SIP/2.0/UDP xx.xx.169.221:5060;branch=z9hG4bK23A1846C
From: <sip:xxx3869800@xx.xx.169.221>;tag=5546D94-1F27
Call-ID: 4E26114D-84CC11E1-91B1BA4D-E011E85F@xx.xx.169.221
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 332
v=0
o=CiscoSystemsSIP-GW-UserAgent 208 564 IN IP4 xx.xx.169.221
s=SIP Call
t=0 0
m=audio 17044 RTP/AVP 0 18 100 101
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
Received:
To: <sip:62993@xx.xx.169.220>;tag=54FBB1C-2B
CSeq: 101 INVITE
Content-Length: 0
*Apr 13 18:21:21.737: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:62993@xx.xx.169.220:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Please advise if we are running into an issue here due to the two SIP trunks and two gateways fo this site.
Note, calls come in on the .221 router.
Best Regards,
Chuck
1 REPLY
Hall of Fame Super Gold
For fax machines, you should use H.323 or SIP, and T.38. Dong this way, you can also bypass CM completely.
Usign MGCP and fax pass-thour is not recommended, and as you're expereinced, likely to cause problems.
220
