issue with g729 on a 2801
2801 voice gateway pri  pvdm-64.. Local calls
going through the gateway as g711 find. Attempts to have remote phone in a region supporting g729 dead air. Call completes, you can see the phone and gateway negotiate g729 but dead air.  I have transcoders available on another but so what they shouldn't be needed.
Re: issue with g729 on a 2801
Hi there,
Need little more info to advise how to go about investigating this
no-audio when placing a g729 call between GW and phone.
Can u advise what  voip protocol is being between GW and CCM ?
What flavor of g729 codec is being negotiated ?
Do u see Tx/Rx pack counts incrementing on ip phone by hitting
"i" or "?" button twice?
What about GW side packet counts - sh call active voice brief ?
I am assuming you don't have a routing issue - u can ping the phone
from the GW using media inteface - correct ?
Did u verify that if u change region setting to setup a g711 call
between that remote hone and GW, u do get 2-way audio ?
IOS ver on the GW ?
Pl. provide as much details as possible...
Thx.
DK
Check your ethernet interface and verify this command is there.
"h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx" (ethernet address)
tracy.larson@mduresources.com
This command has nothing to do with codec and issue here which is no-audio
when using g729 vs g711. All it does is makes sure that GW is sourcing media/signaling
from the bound interface that CUCM is 'aware' of.
Looking at ques. I raised in my earlier post will help us  narrow down the cause
of no-audio issue.
Thx.
DK
yes, i posted this in response to the wrong thread. sorry.
200
