Silver
Issue with Incoming calls
Hi All,
Could you please look at the following debug output and the config and let me know why we are receiving two Calling party numbers for a single call but no called number?
The call comes in with two calling numbers (66244833104 and 6626564) but no called number:
043963: Feb 14 08:33:01.758:
043964: Feb 14 08:33:06.754: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x019A
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Progress Ind i = 0x8083 - Origination address is non-ISDN
        Date/Time i = 0x0C020E0821
                Date (dd-mm-yr)   = 12-02-14
                Time (hr:mnt:sec) = 08:33:108
       Calling Party Number i = 0x2180, '66244833104'
                Plan:ISDN, Type:National
        Calling Party Number i = 0x2183, '6626564'
Here's the config:
trunk group PRI
hunt-scheme round-robin
translation-profile incoming did
trunk group BRI
voice translation-rule 1
rule 1 /^.*\(..\)/ /613\1/
rule 2 /^$/ /61355/
dial-peer voice 999999 pots
trunkgroup BRI
trunkgroup PRI
incoming called-number .
direct-inward-dial
Hall of Fame Super Gold
You should really ask telco that.
Silver
Re: Issue with Incoming calls
Just to let you guys know that we managed to resolve the issue with adding the following commands. It was a timer issue.
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 6000 / added overlap-receiving
dial-peer voice 1 voip
destination-pattern 613..T / add T
modem passthrough nse codec g711alaw
voice-class codec 1
voice-class h323 1
session target ipv4: X.X.X.X
dtmf-relay h245-signal h245-alphanumeric
fax-relay ecm disable
fax rate 14400
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
no vad
235
