Community Member
Issue with Multisite Deployment using MGCP
I have a Call Manger (v 7.15) using PRI trunks and the MGCP protocol running on my voice gateways. I have four Call Manager servers. Two of the Call Managers are at my primary site and the the other two are located at my secondary site. All of the Call Managers are in the same cluster. The primary site has their own dedicated voice gateway and the backup site has three voice gateways. Each voice gateway is registering to their respective Call Managers at the correct location as are the end points (IP phones) that use SCCP.
What has occured is the other day I lost communiction to the primary site which is where the publisher is located. I was unable to process inbound callsro the backup site even though they have their own dedicated voice gateways which were registered to the backup site.
Any ideas or is this is just MGCP being MGCP.
Green
Can you post a sho runn from one of your remote MGCP g/ways.
Can you also list the Call Mgrs as in what the orders are within
the CM groups for the gateway device pools.
Alex
Regards, Alex. Please rate useful posts.
Community Member
Order of CM Mangers for HQ Site:
CM Group at HQ in order:
Subsriber 1 .206
Suscriber 2 .207
CM Group at Hybla
Subsriber 3 - .175
Publisher - .174
Green
Can you post the sho runn from an affected gateway.
Alex
Community Member
The SH run above is the affected gateway that failed at HQ
Green
This all looks OK to me
ccm-manager redundant-host 131.70.206.237 (Secondary Call Processor)
ccm-manager mgcp no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 131.70.206.236  (TFTP Server)
ccm-manager config
mgcp
mgcp call-agent 131.70.206.236 2427 (Primary Call Processor)
service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem relay voip sprt v14 transmit hold-time 30
mgcp ip qos dscp cs5 media
mgcp ip qos dscp cs6 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability mdste-package
mgcp package-capability srtp-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior g729-variants static-pt
May be you could chech the sho log and see if there are any indicators there.
Also look at the syslog viewer in RTMT for the subs involved
Alex
Community Member
Re: Issue with Multisite Deployment using MGCP
I did not see anything that indicated an issue. Of course I can't replicate it without causing a failure
211
