Issue with PRI
Hi All, I am currently facing issue with PRI i can do only 1 outgoing call at time , Service provider tested call on PRI tester its work fine.
VIP Super Bronze
Issue with PRI
What is your setup like? can you give us a brief description of your call flow and include all the elements in it.
Also send us the ff:
1. sh run
2. debug voip ccapi in out
3.debug isdn q931
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Issue with PRI
below is the debug isdn q931
Only 1 outgoing call is working & if i try other then call reaches to receiver number but then no voice hear at both end
Oct 10 10:56:35.234 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x247B Bearer Capability i = 0x8090A3 Standard = CCITT Transfer Capability = Speech Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA9839E Exclusive, Channel 30 Calling Party Number i = 0x0081, '6615314' Plan:Unknown, Type:Unknown Called Party Number i = 0x80, '04844041491' Plan:Unknown, Type:Unknown Oct 10 10:56:35.298 UTC: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xA47B Channel ID i = 0xA9839E Exclusive, Channel 30 Oct 10 10:56:35.618 UTC: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xA47B Progress Ind i = 0x8282 - Destination address is non-ISDN Oct 10 10:56:35.938 UTC: hwic_t1e1_wic_bp_connect: setup failed Oct 10 16:26:35.938 IST: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (0/1/0) to dsp_channel(0/0/1) Oct 10 10:56:35.938 UTC: hwic_t1e1_wic_bp_disconnect: disconnect failed
Issue with PRI
Hello Vijay,
That seems to be the problem:
Could you provide the output of 'show voice dsp' command? Also 'sh inv' and 'sh run' would be useful.
Kind regards,
Andrew C.
Kind regards, Andrew C.
Re: Issue with PRI
Hi , please find
VIP Purple
Re: Issue with PRI
Hi Vijay,
In addition to troubleshooting by Mr. Andrew[+5],can u share show voice dsp group all and show inventory/show diag as well?
regds,
aman
Re: Issue with PRI
Hi issue get resolved after the reload. but its a workaround......
Re: Issue with PRI
You'd better open the case with TAC then, it seems to be the hardware/software problem, not the configuration related thing.
Kind regards,
Andrew C.
VIP Purple
Re: Issue with PRI
Hi Vijay,
You can run the command show voice dsp group all and check the State of DSP.[UP/FAIL] when u face the same issue again.
regds,
aman
Re: Issue with PRI
There are a couple of defects with this same behavior. What is the current ios?
-show version
-show voice dsp group all
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
585
