Issue with Rechability for CUCM on VMWARE
rahul-joshi
I am setting Voice lab at home. I was able to install the CUCM correctly and Can reach  CUCM Webpage from my PC. Following are the Setting
PC Network Adaptor IP: 192.168.10.102/24
Default Gateway: 192.168.10.1 ( is my Router connecitng to internet)
Loopback Adapter is used for connecting VM machine and Router on GNS which provides NTP
Loopback Adapter IP : 192.168.32.253/24 Default Gateway : 192.168.32.254
Router IP Address : 192.168.32.254 which is connected to Loopback Adapter Interface
CUCM IP : 192.168.32.1 Defailt Gateway: 192.168.32.254  NTP : 192.168.32.254
I can use CUCM from my PC and works perfect. CIPC phone installed on my PC works and can register.
Now, I want my other PC which is having IP adddress 192.168.10.104, Default Gateway 192.168.10.1 should reach to CUCM and vice versa.
I tried lot of option like Network bridging etc, but all failed. Can you guide me to do the required changes??
Hi Rahul.
How is the second PC connected to the CUCM?
Can you ping CUCM from the second PC?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Other PC is connected to Router 192.168.10.1
CUCM cannot ping router 192.168.10.1 or 10.104
How is VM Network configured? (Bridged/Nat)
Verify it and set to bridged mod if different.
Remember that loopback interface is a virtual interface and does NOT provide broadcast L2 traffic only layer3 so it doesn't respond to ARP request.
Does CUCM ping its default gw?
Carlo
