Issue with the FAX machine
Hello Folks,
Good Day !
Here we have an issue with the FAX machine which is configured in CUCM 8.5, physically located at Thailand ( On net DN 3083701, PSTN DN +822 344 03701 ). When we call this number either external or local we are getting busy tone... and the debugging logs are quite different in voice gateway.
Logs
When we call to +822 344 03701 we are getting this logs, We want to know why our voice gateway setting up the call 3 times or more than 3 times... Its strange.... Please let me know if you need any other logs from my end... :-)
Jun 27 20:57:56: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F3
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838B
                Exclusive, Channel 11
        Progress Ind i = 0x8088 - In-band info or appropriate now available
        Calling Party Number i = 0x2183, '00213133221121'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '3701'
Jun 27 20:57:56: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F3
Jun 27 20:57:56: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F3
        Cause i = 0x8091 - User busy
Jun 27 20:57:57: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F3
Jun 27 20:57:57: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F3
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F4
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
        Calling Party Number i = 0x2181, '00113133221121'
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F4
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F4
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F4
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F4
Jun 27 20:58:03: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F5
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
Jun 27 20:58:04: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F5
Jun 27 20:58:04: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F5
Jun 27 20:58:04: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F5
Jun 27 20:58:04: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F5
Jun 27 20:58:05: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F6
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838E
                Exclusive, Channel 14
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F6
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F6
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F6
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F7
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838F
                Exclusive, Channel 15
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F6
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F7
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F7
Jun 27 20:58:06: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F7
Jun 27 20:58:07: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F7
Jun 27 20:58:09: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03F9
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98391
                Exclusive, Channel 17
Jun 27 20:58:09: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83F9
Jun 27 20:58:09: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83F9
Jun 27 20:58:09: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03F9
Jun 27 20:58:09: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83F9
Jun 27 20:58:11: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03FA
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98392
                Exclusive, Channel 18
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83FA
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83FA
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03FA
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03FB
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98393
                Exclusive, Channel 19
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83FA
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83FB
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83FB
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03FB
Jun 27 20:58:12: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83FB
When we call to +822 344 03701 from our cell phone 919600054666
Jun 27 21:00:48: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03FC
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98394
                Exclusive, Channel 20
        Calling Party Number i = 0x2183, '001919600054666'
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83FC
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83FC
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03FC
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03FD
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98395
                Exclusive, Channel 21
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83FC
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83FD
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x83FD
Jun 27 21:00:49: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x03FD
Jun 27 21:00:50: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83FD
  • IP Telephony
Everyone's tags (2)
The call is being attempted mutliple times from the gateway because it's receiving multiple SETUP messages from the PSTN. There's nothing wrong with the gateway.
As to why the PSTN would try an engaged number multiple times, I don't know. One vague possibility, is that maybe someone's setup a callback-type service on the number. But you'd probably need to talk to your PSTN provider. (You usually can't get this on ISDN type circuits, so maybe someone/thing is faking it by re-dialling frequently)
GTG
Please rate all helpful posts.
Hi Raja,
This seems to be a port issue, connect the fax machine to a working port and check.
362
