Community Member
Issue with Video calls with CME and Call manager connected by H.323
Hi team,
I have integrated the CME with our Call manager using H.323. I have verified that the audio calls between phones registered to CME and those registered to CUCM are working fine. I have configured the required commands for the video (VTA) to work. Also, the video window is popping up once the call is established, but no video is being displayed. Could you please help me in fixing this issue? I can confirm that the cameras/VTA everything is working fine for all these phones.
Here is the configuration I have done on CME for video:
voice service voip
h323
call start slow
telephony-service
video
maximum bit-rate 256
service phone videoCapability 1
ephone 2
video
mac-address 0022.191D.02C0
type CIPC
button 1:113
When I do a “show call active video” on the CME, I get:
VIDEO:
H320CallType=None
VideoTransmitCodec=None
VideoReceiveCodec=H264
VideoCap_Codec=H264
VideoCap_Format=NONE
VideoUsedBandwidth=1920
Is this problem with the codec mismatch? If so what should I do to fix it?
Swati
Hall of Fame Super Gold
Do you have video working between two CME phones ?
Community Member
I have question like this.
configuration I have done on CME 7.1 for video looks like the same:
voice service voip
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
  call start slow
  h245 passthru all
telephony-service
video
ephone 2
video
mac-address aaaa.cccc.dddd
type 7962
button 1:113
but
no video icon  on ip phones 7962 and 7965
and Video Advantage is not coonected to any phone
even to cipc
when I issued
router2811(config-telephony)#service phone ?
  WORD  enter the phone xml file parameter NAME without <> brackets.
Examples daysDisplayNotActive, displayOnTime, displayOnDuration
         displayIdleTimeout, settingsAccess, garp, pcPort
         handsetWidebandEnable, headsetWidebandEnable
         handsetWidebandUIControl, handsetWidebandUIControl
         g722CodecSupport
router2811(config-telephony)#service phone videoCapability 1
it says there must be  xml file ?
pc is in switchport of ip phone
i did not load tftp loads for phones
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T1.bin"
phone model CP-7962G
load file SCCP42.9-0-2SR-2S
sorry. I found answer.
Once the commands are configured, the create profile
command is required to have the phones provision file update with new configuration.
671
