Issues in RTMT
Hi All,
I have an issue with my RTMT, when I tried to pull the logs for the particular time say 9:00 to 11:00, I am receiving only one file and that file has the traces starts from 13:00. This is one example only, what I mean to say is I am not getting the traces for the requested time. Please suggest.
Lajith
Hi Lajith,This is probably
Hi Lajith,
This is probably because the traces are not present for the time 9.00 - 11.00. The only traces present are from 13.00. This could be because the traces got overwritten due to the volume of calls.
To confirm  whether RTMT is making a mistake, I suggest you list the trace files present on the server by using the CLI.
Go into CLI
admin: file list activelog cm/trace/ccm/sdi(sdl)/ date detail
This command will give you the details of the CCM trace files present and the time that they were written.
For the location of all other trace files, here's a document. https://supportforums.cisco.com/document/65651/communications-manager-rtmt-trace-locations-cli
What is the CUCM version? By default, in 9.x, the CCM traces are in detailed mode.
Hi Sreekanth, I have executed
Hi Sreekanth,
I have executed the commands but no luck, here is the output
admin:file list activelog cm/trace/ccm/sdi
dir count = 0, file count = 0
admin:
admin:
<dir>   Proglogs
<dir>   calllogs
<dir>   sdi
<dir>   sdl
dir count = 4, file count = 0
CUCM Version : 8.5.1.16102-1
RTMT Version : 8.72(007)
Hi Sreekanth, Sorry. My
Hi Sreekanth,
Sorry. My mistake, I should had login to subscribers. The earlier output was from publisher. I see as per the subscriber the logs are overwritten.
Hi Lajith,Yes, since the logs
Hi Lajith,
Yes, since the logs are overwritten, you cannot pull the older ones anymore.
Sree
Hi Sreekanth, Can we increase
Hi Sreekanth,
Can we increase the log buffer size?
Hi Lajith,Yes, you can
Hi Lajith,
Yes, you can increase the log buffer size, and the number of files recorded as well. But increasing the buffer size can put a strain on the CPU. Increasing the number of trace files can cause more disk space to be utilized.
Another alternative that you can approach is to dump the logs to SFTP server regularly so you can then review the traces and delete if not required.
Hi Sreekanth,It would be
Hi Sreekanth,
It would be great if you could explain how we can increase the buffer size and configure sftp to dump the logs.
Or please provide me the document where I can refer it.
The size of the files and no.
The size of the files and no. of files can be changed in the Trace -> Configuration page for the Cisco Call Manager service. You will see the two fields under the rest of the various checkboxes.
Here's a guide to scheduling trace collection.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/5_1_3/ccmsrva/ccmsrva/sartmttc.html#wp1090215
Hi Lajith,There are no files
Hi Lajith,
There are no files present in the sdi directory. So the RTMT won't give you any result.
What about listing the contents of the sdl directory. What do you see there?
Is the CCM service activated?
109
