issues with call manager
Hi friends,
I have a few issues with my CUCM 6.0 business edition installation and would like some help.
One, how would i enable particular extensions to call other extensions anonymously, ie only name displaying but not extension number? is there a simple way to achieve this.
second, how does one achieve direct outward dial with CUCM and a h.323 gateway, there seems to be very little on the Cisco site on this issue.
third, how effective is CAR/CDR without a third party billing system. Can i use it to effectivly bill people within the organisation. I have added a user as a CAR/CDR admin but i am not able to view a report with all the users details. I am only able to view that particular users' call records and the top users. I need to generate a report for all the users. any ideas?
thank you
Re: issues with call manager
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
Cisco IOS H.323 Configuration Guide
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_h323_configuration_guide/old_archives_h323/323confg.html
Cisco IOS H.323 Gateway Configuration for Use with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Dial Peer Configuration on Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
it's limited, non customizable and only can provide certain information. useful if you only need basic reports
add the user as a CAR Admin as it seems you only granted access to CAR as user (since he only can see his own data)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Java,
the call display restrictions worked. however i am having a problem i think with Calling search spaces as i cannot dial the phone with call display restrictions though i can call from it. This is only for internal numbers.
for the direct outward dial i am still stumped, does cisco have no command like for direct inward dial? Do u have to manipulate the dial plans?
Thanks for your help. will keep you updated.
regards
Eric Mwangi
sounds like CSS indeed, take some time to review the call flow. calling needs to reach TP, TP needs to reach final destination. check that carefully
no, we don't have a command for DOD, just configure the necessary dial-peers on the gateway, it's nothing really special.
where and what do you want to change on dial-plans??
java
java
205
