Issues with corporate Directory lookup from IP Phone
i cant access the corpotare directory from the IP Phone. my ccm is ver 4.1
Its Displaying "Authorization Required" on the IP Phone screen.
I have one CCM server 4.1(3).When i am trying to take services or directories from ip phones which is registered on CCM, is asking authorization username and password. I tried username and password which is associated with the phones. but it is not takng. CCM is not integrated with any AD system. How can i remove this Authorization. Pls help me... Thanks........Kunle
1 REPLY
Re: Issues with corporate Directory lookup from IP Phone
Try running adminutility after-hours and then issue an iisreset via cmd prompt
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
643
