03-19-2007 08:48 AM - edited 03-14-2019 08:33 PM
the aim:
view the MS calendar or MS task or both from cisco ip Phone 7900 series
i have cisco CME 4.0 and MS exchange 2003
03-19-2007 10:49 AM
You would need some sort of 3rd party application to be able to read from Exchange, authenicate and push out XML to the designated IP phone. You may want to try LiteScape.
03-20-2007 08:35 AM
hii thanks for you , but if u ca tell me the name of the software(3rd party application that help me to do this)
03-20-2007 09:27 AM
There really is not a piece of software that does this. LiteScape may be able to build a solution, or have a solution for you. They do a lot of work in customizing the XML screens for IP Phones. (hooks into PeopleSoft, AD, CCM, etc).
