Its possible a 7941 with 7914 addon on CCME?
I would like to know if it is possible to attach the 7914 addon on the 7941 phone, like the 7940.
With the 7940 works adding "type 7960 addon 1 7914" on the ephone config, but I'm trying to do the same with the 7941 and it doesn't work.
I tried uploading/downgrading the firmware version of the 7941 and the 7914 without success.
This is the tftp event debug message:
"5w5d: TFTP: Looking for S00104000100.SBN
5w5d: TFTP: Opened flash:S00104000100.sbn, fd 0, size 49169 for process 154
5w5d: TFTP: Finished flash:S00104000100.sbn, time 00:00:00 for process 154
Configuration commands:
tftp-server flash:S00104000100.sbn
telephony-service
load 7914 S00104000100
ephone 22
mac-address 001D.xxxx.xxxx
type 7961 addon 1 7914
button 1:12
The 7941 boot the first time with a "OK" square, then reset 3 or 4 times whit the "wrong" square on the left-bottom corner, and finally the 7941 remains registered and the 7914 with the red buttons on.
The ios version is 12.4.11T4.
Thank You
Re: Its possible a 7941 with 7914 addon on CCME?
According to Cisco the 7914 is only supported on the models listed in the following data sheet:-
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a008008883d.html
Allan.
Hi Allan,
I know it, 7914 don't support 7940 but it works, may be it works with the 7941...
Gerard
773
