Community Member
Its urgent CPU utilization is high.
I have one ccm 4 cluster. One publisher and two subscribers in this cluster. But from few days ago publisher CPU utilization is so high (approximately 100%). In task manager i saw that winMgmt.exe is eating 50-52% CPU. I have restarted the publisher server but still same problem how can I solve it.
1 REPLY
Re: Its urgent CPU utilization is high.
Hi Rashed,
You are hitting the BUG CSCsg22151
This BUG has been fixed in OS 2.0(4.3a)SR4
and simply you can do this workaround:
Click Start, click Run, type wmimgmt.msc, and then click OK.
2. Right-click WMI Control (Local), and then click Properties.
3. Click the Logging tab, and then click "Disabled" under Logging level.
4. Click OK.
5. kill winmgmt.exe
Wish this be helpful
Best Regards
109
