ITS with remote office
I have HQ and BR1, i need BR1 people to call the HQ but hit the AA not the extension directly.
I am using the AA ITS not the B-acd. i can see that i can enable it on the voice-port but in my case i have voip not pots
please advice
Good day
Hall of Fame Super Gold
Re: ITS with remote office
What is AA ITS ? What prevent you from using B-ACD ?
This said, generally speaking, when a service works for pots, should work for voip too.
application
service autoatt flash:its-CISCO.2.0.1.0.tcl
dial-peer voice 10 pots
service autoatt
destination-pattern 9T
port 0/0/0
the customer need from the AA to press the extension or 0 for operator
so what you are saying is that if i do the following it should work
dial-peer voice 11 voip
service autoatt
incoming called number .
I will give it a try
Good day
I think that is just an older version of B-ACD/AA under another name.
You need codec g711u under DP to be able to listen to prompts.
here is the result after the setup
Config
application
paramspace english language en
paramspace english index 1
param operator 1001
paramspace english location flash:
paramspace english prefix en
param en 0
dial-peer voice 1005 voip
service autoatt
incoming called-number 1005
dtmf-relay h245-alphanumeric
codec g711ulaw
calling 1005 from another router will result as follow:
debugs:
*Apr 13 07:32:18.633: //64//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
ANI 3002
DNIS 1005
*Apr 13 07:32:18.641: //64//TCL :/tcl_PutsObjCmd: IP IVR Disconnect Status = RESULT=di_001
Call failed. Play prompt and collect digit
proc act_Select
proc act_DestBusy
i think it is not supported on VOIP, it plays the disconnect prompt directly, i will try b-acd instead
more debugs:
debug voip application media
CME(config-dial-peer)#
*Apr 13 07:52:06.099: //-1//DPM :DP9:/pc_mc_addToDynamicS: (1) _disconnect.au
*Apr 13 07:52:06.099: //-1//DPM :DP9:/pc_mc_addToDynamicS: Doing : _disconnect.au
*Apr 13 07:52:06.099: //-1//DPM :/mcTokenizerGetNext: savedcharptr=_ endptrptr=_disconnect.au
*Apr 13 07:52:06.099: //-1//DPM :DP9:/pc_mc_addToDynamicS: Token : _disconnect.au status 1
*Apr 13 07:52:06.099: //-1//DPM :DP9:/dp_mcDQfromFileDynamic: pLanguage=en FileName=_disconnect.au
*Apr 13 07:52:06.099: //-1//DPM :DP9:/dp_mcDQfromURL: file=flash:en_disconnect.au
*Apr 13 07:52:06.099: //-1//MCM :/mc_createFromFileUrl: Getting a media content: name=en_disconnect.au
url=flash:en_disconnect.au
load fast, fetchtimeout=-1
*Apr 13 07:52:06.099: //-1//DPM :/mcTokenizerGetNext: savedcharptr= endptrptr=
*Apr 13 07:52:06.099: //31//MSW :/msw_create: cbf=0x41CEDA7C
*Apr 13 07:52:06.099: //-1//MSM :MS15:/ms_create: Iniz ply_timer
*Apr 13 07:52:06.099: //31//MSW :/msw_synth_open: mediaStream 0x45E2CEC8 created
*Apr 13 07:52:06.099: //31//MSW :/msw_synth_open: rtspStream 0x4778D8D0 created,
status=RTSP_STATUS_SUCCESS, session_id=0xF (15)
*Apr 13 07:52:06.099: //31//MSW :/msw_synth_open: AIS : Creating TTS AIS Backend record
*Apr 13 07:52:06.099: //-1//MSM :MS16:/ms_create: Iniz ply_timer
*Apr 13 07:52:06.099: //31//MSW :/msw_recrd_open:
*Apr 13 07:52:06.099: :msw_recrd_open mediaStream 0x46B23BC0 created
*Apr 13 07:52:06.099: //31//MSW :/msw_recrd_open: rtspStream 0x4778D8D8 created,
status=RTSP_STATUS_SUCCESS, session_id=0x10 (16)
*Apr 13 07:52:06.103: //31//MSW :/msw_recog_open: AIS : Creating ASR AIS Backend record
*Apr 13 07:52:06.103: //-1//MSW :/msw_associate_call:
*Apr 13 07:52:06.103: msw_associate_call: callID=0x1F(31),
genericStream=0x477F0A48
*Apr 13 07:52:06.103: //31//MSW :/msw_synth_get_stream_state: genericStream 0x477F0A48 is in state MSW_S_IDLE
*Apr 13 07:52:06.103: //31//MSW :/msw_synth_start: current_stream_id=1, content 0x0, dynamicS 0x45E2CE78, current_state=MSW_S_IDLE
*Apr 13 07:52:06.103: //31//MSW :/msu_synth_partial_play: Media Stream URL
*Apr 13 07:52:36.127: //-1//MSW :/msw_synth_bargein:
*Apr 13 07:52:36.127: msw_synth_bargein: genericStream=0x477F0A48,
For some reason (busy ?) it fails. You can send all calls to operator directly even with a script anyway, just make a translation rule on the incoming dp. Or B-ACD should work.
you are right b-acd worked fine.
Good day
140
