%IVR-3-LOW_CPU RESOURCE: on VG 2821
Hi all,
i´ve a got a problem with a 2821 voice gateway and i see the following message in log file
Apr 23 16:04:37.338: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu
utilization (96/100).
     Call (callID=382702) is rejected.
sh version
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-ipvoicek9-mz.124-24.T1.bin"
sh processes cpu history
1 1 21 11 1 31 999999999999999
455526444515430465555168455637615765556777877677666606666566
100 *#***** *******
90 *####*****##*#
80 *####****#####
70 *######*######
60 *#############
50 *#############
40 ##############
30 * ##############
20 * * ** ##############
10 ***** *** #* ******** ***#**#************###############*
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
99998962 9 9 98 9 99 1 49 1 4199
777737636555555555555565556575555555555555557668778392786855555515588177
100 **** * * * * * ** * **
90 **** * * * ** * ** * **
80 ****** * * ** * ** * **
70 ******* * * ** * ** * **
60 ******* * * ** * ** * **
50 ******* * * ** * ** * * **
40 ******* * * ** * ** ** * **
30 #*##*** * * ** * ** ** * **
20 #*##*#** * * ** * #* *# * **
10 ####*#********************#*#*******************##****#***************##
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
sh processes cpu sorted 1min
CPU utilization for five seconds: 4%/0%; one minute: 3%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
68 8663700 112909121 76 1.03% 1.01% 0.98% 0 Skinny MOH Serv
e
156 150020 563217513 0 0.47% 0.42% 0.40% 0 HQF Shaper Back
g
5 4823316 341002 14144 0.95% 0.30% 0.25% 0 Check heaps
9 79184 7652091 10 0.31% 0.25% 0.24% 0 Skinny Msg Serv
e
272 22188 141573071 0 0.15% 0.13% 0.13% 0 HSRP Common
255 305324 639087 477 0.23% 0.12% 0.04% 0 VOIP_RTCP
265 604720 274136 2205 0.00% 0.07% 0.02% 0 CCSIP_SPI_CONTR
O
128 18004 3517829 5 0.07% 0.04% 0.05% 0 CEF: IPv4 proce
I cannot find anything on cisco web page for this issue and this firmware. Anybody an idea what can i do?!
Many thanks,
cristina
  • IP Telephony
Hall of Fame Super Gold
Seem there is nothign to worry about.
I'd recommend you update IOS anyway...
Green
Cristina,
This what the error decoder thinks of your alarm
1.
%IVR-3-LOW_CPU_RESOURCE:IVR: System experiencing high cpu utilization ([dec]/100). Call (callID=[dec]) is rejected.\n
The system does not have enough CPU resources available to accept a new call.
Recommended Action: Ensure that the call setup rate is within the supported capacity of this gateway.
Related documents- No specific documents apply to this error message.
I am with Paolo, I would upgrade the IOS first of all
If you have at least 256M DRAM & 64M Flash
Use c2800nm-ipvoicek9-mz.124-24.T7.bin
Alex
Regards, Alex. Please rate useful posts.
1328
