IVR Prompt Error - TCL Script
I'm trying to get the 'clid_authen_collect' built in script working. I continue to get the below error.
" enter_account.au
errno=0=Unsupported samples per secondpr"
I used Audacity to create prompts with below specifications:
Default Sample Rate: 8000Mhz
Default Sample Format: 32-bit float
Uncompressed Export Format: AU Sun/Next 8-bit Ulaw
channels: 1 (mono)
FFT Size: 64
Can someone who's created prompts in the au format let me know what exact specs the router wants in order to execute the prompt.
thanks in advance,
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: IVR Prompt Error - TCL Script
Yes, you need DSPs.
the specs are as follows
codec- G711ulaw
8 kHz
8 bit
Mono
other than that, im not too familiar w/Tcl, so im not sure why you are having an issue.
Appreciate the quick response. Do you know of another recording utility that I can use to create the .au audio files?
Im not really sure, like I say, Im not too familiar with this sort of thing, I just happened to know the spec, but Ive never had to make an actual recording.
Adobe Audition
Hi, the problem is the sample format that I think should 16 bits, not 32.
Anyway, to record prompts in a simple way, you can use the recorder that I wrote:
http://pbevila.fastmail.fm
You can use it with any voice device that can call the service one way or another.
EDIT: I haven't checked, it can very well that sample has to be 8 bits as mentioed above.
HI Paolo.
I got a directory index denied when I tried to hit your page. I'd love to try your recorder out.
After my last post, I used the Switch Sound File Converte and I no longer get that error, but I still can't hear the prompt.
As always i'll rate the post before closing this issue out.
BTW, last format that I save with Switch Sound File Converter was:
output format .au
codec: ulaw
sample rate 8000
channels mono
It doesn't give me the option under Ulaw to save as 16 bit. If I switch to PCM I could define 16 bit.
Paolo,
I added /public to URL and was able to get in.
However I took one of your prompts, renamed it and uploaded it. When I do a debug voice application media packet I see the prompt is active, but still no sound heard. Any ideas?
Attached is my config if you have time to look.
Hi, you need codec g711u for all and any DP that has tcl/ivr service with prompts.
Sorry, here's the correct url:
http://pbevila.fastmail.fm/public
Also, if you download:
http://download-sj.cisco.com/cisco/access/tclware/debitcard-multi-lang-Cisco.1.1.0.2.zip
There's a lot of prompts in there that you can reuse.
finally remember that for "static" prompts, when prompts change, you ned to reload the router to load the new one. That is a current issue in IOS.
I'm trying to get your script to run. I really want to get this running as I have a real need for it. I loaded script and prompts in flash, rebooted, then configured applicaiton and voip dialpeers. When I call from one router over to this one, I am getting an error "Error Adding URL to Prompt list". Do you know why this happens? I've attached config and debug voice application error.
appreciate your help.
Please configure paramspace commands for the script.
Still no luck. Let me ask you, even though all calls to and from router running TCL are using G711, do I still need DSP resources? If so, does the router grab available DSP's (maybe to play the prompts) or do you have to have a transcoder setup?
sorry for the hassle.
Yes, you need DSPs.
738
