IVR Transcoding on CUBE
Hello!
I've got CUBE on 2901 with IOS c2900-universalk9_npe-mz.SPA.154-3.M.bin.
SIP provider uses g711 alaw  codec for SIP trunk.
I need to transcode incoming calls from g711a to g711u before playing IVR script.
I've configured transcoding profile on CUBE(in telephony-service, also I can use LTI as I know), but how can I enable transcoding on CUBE, so that it works in SRST mode too?
How many dial-peers do I need for solving this problem?
One incoming from provider with hard-coded g711a and another for IVR with g711u?
I know that transcoding turns on when one call leg is in one codec and second call leg is in another codec. How can I terminate incoming call from one to another dial-peer?
I tried with voice translation rules, but it doesn't work, router chooses incorrect DP or don't chooses outgoing call leg at all....
Sample of config:
application
 service test flash:/ivrfax.vxml
voice translation-rule 3
 rule 1 /308042/ /555/
voice translation-profile 308042_income
 translate called 3
dial-peer voice 1 voip
 description To_CUCM
 destination-pattern [1-8]...
 session protocol sipv2
 session target ipv4:10.128.2.2
dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 2 voip
 description To_CUCM
 session target ipv4:10.128.2.3
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 308042 voip
 description ---Outgoing to SIP 308042---
 translation-profile outgoing 308042
 destination-pattern 9T
 session target sip-server
dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 30804242 voip
 description from_Provider_incoming
 translation-profile incoming 308042_income
 incoming called-number 308042
dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 555 voip
 description IVR
 service test
incoming called-number 555
dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Thanks for any help or information!
it should work in SRST What
What is your call flow and what is your current issue apart from xcoder
My issue is problem with
My issue is problem with xcoding of incoming calls to IVR. I don't understand how can I do it using dial-peers or voice-translation rules. In debug ccsip mess it always chooses dial-peers 1 or (wrong) or there is not any outgoing DP when I change some settings in config. What I am missing for?
So, can anybody help me?I
I tried to only one one incoming dila-peer, but I don't hear anything in my audiofile via call, call establishes in g711a codec.
https://supportforums.cisco.com/discussion/11978696/transcode-incoming-calls-and-ivr
Hall of Fame Super Silver
Have you reviewed this for
Have you reviewed this for dial-peer matching understanding:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Where is the call going to connect under SRST, will the IVR still be available?
You can use telephony-service (CME) and register xcoders to it, keep in mind that to transcode between u-law to a-law you will require universal transcoders and not traditional transcoders, so review config for universal transcoders.
Chris
Yes, I read this document. I
I've created ccm group, sccp local interface, dspfarm profile, and registered it to telephony-service. It's ok.
Yes, IVR still be availible under SRST, it runs as vxml script on router flash.
I configured router for inbound/outbound calls in g711a, and it works fine. But when using IVR with .wav file in g711u codec I've got a problem. I decided to use translation-profile on incoming dial-peer, from incoming number to internal IVR number, but it doesn't work.
I attached config of xcoder, dial-peers and translation rules.
In normal mode (without IVR) I receive calls in dial-peer voice 30804242 voip and after it translate them to dial-peers 1 or 2 to CUCM phones.
286
