IVR
Hi. Sorry for a silly question, but i don't can find system request and install notes for IVR. You can help me?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: IVR
Hi Slava,
Not a silly question at all my friend :) Is this what you are looking for?
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_6_0/installation/guide/gsipivr.pdf
Hope this helps!
Rob
Silver
Re: IVR
The only think I can officially tell you is to work with your Cisco people to see if they can send you a VMware image.
You can use the Vmware converter to take an image of a real IPCC server, but installing the Vmware converter will probably invalidate TAC support.
Re: IVR
Hi Slava,
Hope this helps!
Rob
Re: IVR
Re: IVR
Hi. I can install IPVR into virtual mashine VMWare?
Re: IVR
Yes you can.
Re: IVR
But i install crs on vm, i see next messages "Computer hardware provided by cisco required to install CCRS. Instalation will now abort.
I have VM hardvare
hdd 15Gb
Ram 2GB
CPU 2Gz
Re: IVR
Which system hardware request for CCRS 5. If i want install it into Vmware?
Blue
Re: IVR
CRS requires specific cisco supplied MCS servers.
I've got a few CRS systems running on a couple of VMWare systems so if you'd like the steps and software required to get it working, let me know.
ftpaccess@ccieme.com
Re: IVR
Hi.
You can send me steps and software, hardware required to get it working?
mail: sazanov@sunline.com.ru
Thank you very mach in advance
Silver
Re: IVR
Just to set the expectation straight, installing CRS on VMWare means no support from Cisco.
So hopefully you are only installing a test system.
Re: IVR
yes, i know CRS installing on VMWARE no support from cisco.
Re: IVR
But i can install CRS on vmware for tested?
if yes, how i can install CRS on vm mashine?
Silver
Re: IVR
Re: IVR
ССМ 6.1 has integrated IPVR, how ССМ 4?
Silver
Re: IVR
I am not aware of any IVR in 6.1 or 4.1.
Cisco's definition of IVR is a self-serving application, usually involving database dips or similar. Like calling the bank to input your checking account number and having it speak back your balance. Also to move money between your checking and savings account.
Cisco's definition of prompt and collect: Give the caller a spoken prompt and collect DTMF (or ASR) responses. Kind of like AutoAttendant functionality. Press or say 1, call gets transferred "here".
ACD is the queuing of calls to be answered by an "Agent".
Re: IVR
Thanks.
182
