Jabber and corporate directory
Hi guys
Scenario:
HQ and remote site connected throught vpn
In the remote site we have 3 users which their pcs are in different domain From the  users in HQ site
For the other hand ,  the remote users are in the HQ domain for the  loggin in jabber
So the remote users use B domain for loggin into their pcs BUT for the loggin in jabber they are in A domain(which is the domain for the HQ)
The problem is that the remote users cant see in the jabber search field the users in the HQ
The HQ users can see the users in the remote site
Any ideas?
PS:
I cheked into the remote users/pcs and its there the jabber-config.xml into this path
C:\Users\a.ker\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
And have you configured a domain A user in the.xml for those users to log into LDAP???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi java
i have only the below into the remote users
UDS
Pls guide me if you see something wrong
No i didnt configure anytrhing extra
Just i have uploaded the above into the cucm(tftp) and then when they loggin they take this config
Chrysostomos
Then that's your problem, by default you use the domain credentials to log into LDAP and do searches, so, if they don't belong to the domain, it won't work, you need to create a special .xml for those users on which you hardcode a user from domain A, along with pwd, searchbase, etc so they can do that.
The documentation for Jabber from which you got the parameter on how to configure UDS as the directory, also has all that info.
java
java
Jaime
Thnak you for youre inputs
I read this manual and the reaosn that i have asked a discussion is because i wouldnt be able to create a correct xml config for my issue
So i am kinldy ask if you can help with that
Chrysostomos
158
