Community Member
Jabber cant make external calls.
I am haveing trouble making external calls from my iphone using Jabber. Internal calls are fine, here is the config can anyone help??, :-
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address 192.xxx.xxx.xxx port 5060
max-dn 8
max-pool 8
authenticate register
tftp-path flash:
file text
create profile sync 0016587035046146
voice register dn  1
number 8001
name xxx
label xx
voice register dn  2
number 8002
name xx
label xxxx
voice register pool  1
registration-timer max 720 min 660
id mac 04F7.E4C3.xxxx
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
username xx password xxxx
voice register pool  2
id mac 78CA.3997.xxxx
number 1 dn 2
username xxx password xxxx
description xxxx
dial-peer voice 44 voip
description UK CALLS WITH 0044
destination-pattern 0044..........
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay sip-notify rtp-nte
ip qos dscp cs5 media
clid network-number xxxxxxx
no vad
dial-peer voice 49 voip
description GERMANY CALLS WITH 0049
destination-pattern 0049.........
voice-class codec 1
no vad
dial-peer voice 43 voip
description AT CALLS WITH 0043
destination-pattern 0043..........
voice-class codec 1
no vad
dial-peer voice 1 voip
session target ipv4:192.168.3.100
incoming called-number xxxxxxxx
sip-ua
authentication username xxxxx password 7 xxxxxxxxx realm sipgate.co.uk
authentication username xxxxxxx password 7 xxxxxxx realm sipgate.de
no remote-party-id
set pstn-cause 6 sip-status 503
set pstn-cause 18 sip-status 408
set pstn-cause 27 sip-status 502
set pstn-cause 31 sip-status 480
set pstn-cause 44 sip-status 503
set pstn-cause 58 sip-status 503
set pstn-cause 88 sip-status 503
set pstn-cause 95 sip-status 503
set pstn-cause 102 sip-status 504
set pstn-cause 111 sip-status 500
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 10
timers trying 1000
timers connect 100
timers register 250
registrar 1 dns:sipgate.co.uk expires 3600
registrar 2 dns:sipgate.de expires 3600
sip-server dns:sipgate.co.uk:5050
telephony-service
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 192
ip source-address xxxxxxxxxx port 2000
service phone displayIdleTimeout 00:30
service phone displayOnDuration 1:00
timeouts interdigit 8
timeouts ringing 20
system message xxxxx
cnf-file location flash:
cnf-file perphone
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
load 7921 CP7921G-1.4.3SR1.2
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name xxxxxxsecret 5 $xxxxxxxx
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 1001
ephone-dn  2  dual-line
number 1002
ephone-dn  10
number xxxxx secondary xxxxx
ephone-dn  11  dual-line
number xxxxxx
ephone  1
no multicast-moh
mac-address 001F.9E8B.xxxx
max-calls-per-button 4
username xxxxx  password xxxxxx
type 7921
button  1:10 2:11 3:1 4:2
ephone  2
description Gxxxxx
mac-address 0026.5AE3.9F6F
type CIPC
ephone  3
description Gxxxxxx
mac-address C485.086C.95A3
Everyone's tags (4)
589
