Jabber client for SAMSUNG S3 on cucm8.62
HI
i am having problem registering jabber cliet( on samsing s3 andriod 4.0)  on cucm8.6.2 . after giving  all the details  devicename and cucm ip address
it is not working . but it works perfect on s2 phones .
please give a solution ...
regards
raja
That one doesn't seem to be compatible nor tested to work
Requirements for users and devices
The following Android devices are supported:
Samsung Galaxy S International  (GT-I9000) with Android 2.2.1 or 2.3
Samsung Galaxy Tab International  (GT-P1000) with Android 2.2.1 or 2.3
Samsung Galaxy S II (AT&T)  with Android 2.3
Although not officially supported, Cisco Jabber for Android runs on many  Android OS 2.2 or 2.3 devices with various limitations depending on the  device. For information about running Cisco Jabber on unsupported  devices, see the Cisco Support Forums at http://supportforums.cisco.com.
The Cisco Jabber for Android application is available through the Google  Android Market. Your device must run either Android OS 2.2 or 2.3 to  access the Cisco Jabber application.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Android/8_6/Cisco_Jabber_Android_8_6_2_RN.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Javalenc. Is there a plan by cisco to make Jabber compatible with the Samsung Galaxy3 Android version 4.0.4. I work in pre-sales for a company called Kcom in the UK and I want to perform a demo on Monday of the Cisco Jabber client to my client ASDA Walmart. Can you please help!
Much appreciated mate.
Best regards
Matthew Cullen
HI
Any workaround are new client for this
please advise
although it is not supported by cisco by it was working with me on S3 as well as Note .... some features are not supported offically from cisco ...
check your setting, profile name etc
Hi Zubair
Please find the attached image of my setting , guide me were i was wrong ...
Hi Zubair
No luck still
Please can you share the Sip profile  and phobe button template you have created .
i was using standed  for  both
if it is working on S2 than what profile u created for that ....
how you are trying to connect ... on wifi .... i am using standard sip profile which was mentined before ...
898
